Drag to reposition cover
BUILD Supercharged C5
1quick
Posts
23,256
coal city
Nice upgrades, what sort of power are you going to be making?
ldyzluvdis06
ldyzluvdis06
Supercharged C5
Posts
5,984
Jacksonville, IL
we should meet up sometime for some fun runs when your car is together again
im not local. but if you're ever down in central illinois than i'd be more than willing to.
will the trans be able to handle the power ?
I am currently running a level 2 performabuilt 4l60e that's rated for 700hp. next winter ill probably pull it out and send it in to be upgraded to their level 3 trans. I opted to pay for their 2 year warranty and anytime within the warranty period you can send it in and just pay the difference of the two transmissions.
should be mid 700 to the wheels without getting aggressive on the tune. im going to need more injector and pump to push any higher. Also going to blow up the stock bottom end at some point as i am currently on borrowed time. im stock bottom end, stock heads. but when it goes, i plan to just swap in a 5.3 and sendit
ldyzluvdis06
ldyzluvdis06
Supercharged C5
Posts
5,984
Jacksonville, IL
picked up some new shoes today for the upcoming season! *side note* the sticker really isn't that obnoxious. i cut it out of reflective black so you can't really see it, unless you're behind me at night time. :hsugh::drums:
ldyzluvdis06
ldyzluvdis06
Supercharged C5
Posts
5,984
Jacksonville, IL
new blower installed. i upgraded from the self contained Si unit to an oil fed Ti unit with HD straight cut gears. also went down from a 3.4" pulley on the Si to a 3.25" on the new HU. Haven't thrashed on it much as im still needed to install the new diff (c5 diff with c6z internals and 3.42 gears compared to my current 3.15). also need to install diff mount, fuel rails/lines, and FP gauge. Then ill be getting with my tuner and refreshing the tune.
ldyzluvdis06
ldyzluvdis06
Supercharged C5
Posts
5,984
Jacksonville, IL
fuel rails, fp gauge, diff, diff mount finally installed. now im just waiting on my tuner. in the mean time, i had the side window tint removed and had 5% put on instead (it was 35%) i need to clean up my catch can hoses and wash the engine bay. lol
Prior to tint
ldyzluvdis06
ldyzluvdis06
Supercharged C5
Posts
5,984
Jacksonville, IL
not much to update here. still waiting on the tuner for my dyno tune for the larger blower, its obviously running a little lean from last year since last year had a smaller blower and larger pulley. afr at wot is around 12.0-12.3 so im not doing much. i have made a couple of small pulls, but nothing that has amounted to anything, and both times the car left me stranded. just this year i have popped another trans cooler line (situation should be resolved now), popped an IC pipe 4 different times (again, should be permanently resolved), during a quick race i sheared the water pump pulley, and during last night testing i blew out a radiator hose. all this shit has me worried about when we tune it, with my luck, the stock bottom end is probably going to throw in the towel.
ldyzluvdis06
ldyzluvdis06
Supercharged C5
Posts
5,984
Jacksonville, IL
was last night when the radiator hose blew and soaked the car in coolant after i had just finished detailing it earlier in the day.
ldyzluvdis06
ldyzluvdis06
Supercharged C5
Posts
5,984
Jacksonville, IL
while towing the car using truck and a strap, also broke the bumper last night when we were making the 5mile tow back to my place. im to cheaper to replace the bumper, so ghetto fix it is. i need to pick up some clear or black zipties, but red is all i had on hand.
10sec
Posts
24,991
Damn that does suck, some unfortunate sequences of bad luck there.
95SC
4 cams
Posts
3,339
TN
Coyote swap it and all your typical GM problems will go away
ldyzluvdis06
ldyzluvdis06
Supercharged C5
Posts
5,984
Jacksonville, IL
someone mentioned on fb that i may have a bigger issue on hand. they mentioned that it's common for 6.0's to blow a coolant hose when they lift a head and/or blow a head gasket. so now im worried that may have been what happened as this was the first time i revved it that high and made a full pass since the new blower was installed, and the tune hasn't been adjusted for it. any recommendations on how i can diagnose to determine if that's what happened?
1quick
Posts
23,256
coal city
I’d imagine if you pressure test the coolant system it would tell you if you lifted a head
Yea but how many acres..?
Posts
61,431
Yup. See how much psi you got. T a psi gauge in and go for a ride. Shouldn't be more than 14 psi
ldyzluvdis06
ldyzluvdis06
Supercharged C5
Posts
5,984
Jacksonville, IL
i replaced the hose and did some diagnosing to try and determine my issue. pulled the plugs and they all looked good. did a compression test and all 8cyl were damn near exactly the same as the compression test that was completed a few weeks prior to the issue. Did an engine combustion leak test via the coolant reservoir (did this a couple of times) and came up negative.
so we went ahead and did some more street tuning to adjust the fueling for the larger blower. we noticed i was blowing coolant out of my radiator cap so we pulled the dipstick and a couple of plugs and they still looked good. nothing in the tune indicated a lifted head either. so i purchased a new coolant reservoir cap so hopefully that solves the issue.
car is running great, otherwise. tune looked good and tuner stated he didn't see any thing out of the ordinary. car is still tuned very safely as my tuner doesn't like pushing FI/E85 cars on the street and prefers dyno tuning them. I am maxing out my injectors (FIC1000's because im not running a boost regulated FPR) but he said when we get on a dyno he should be able to add some timing still and see what the car is happy with. i did notice a leak in the rear end, appears to be from the new diff, axle is flinging grease everywhere, and i have a small coolant leak out of the front (possibly the radiator itself). so im going to pull the diff this weekend to diagnose and resolve, and also replace the axle. the radiator will have to wait a few weeks because the wife is already bitching about the amount of money i have been spending (not just on the car).
A bunch of little shit, but that's to be expected with a 19 year old car with 155k miles that i beat the shit out of and put a lot of miles on.
ldyzluvdis06
ldyzluvdis06
Supercharged C5
Posts
5,984
Jacksonville, IL
that's a lot of reading, so here is a pic in case you don't want to read the actual update.
Shine courtesy of Turtle Wax Show 'n Shine
SirMarco
of Pingree Grove
Posts
12,167
Pingree Grove
Dam do want a C5.
Got a few things to handle this year but next season I think I want to get back into a car.
That looks great.
