BUILD Supercharged C5
ldyzluvdis06
Supercharged C5
Posts
6,052
Jacksonville, IL
[chapter]Goodbye 335, hello C5[/chapter]
Traded the 335i a couple weeks back and picked up a 00 C5. It was to good of a deal not to, honestly. The Bmw had a rebuilt title, and booked for $9k with a clean title, so i could have probably sold it for around 6 or a tad higher. i traded the car plus $3k on my side.
Car is a 2000 C5, 112k miles, auto, A&A V3 supercharger kit, JBA headers, Magnaflow catback, summit racing balancer, BTR dual valve springs, plugs, msd wires, kenne belle boost a pump, all 4 stabilizer links new, glass targa top and painted top.
Car was dyno tuned in oct 2016 at 498whp at weaponX in OHIO but the car felt slow. drove it home and had my tuner pull the file and it's extremely low on timing so that has me worried, as to why they pulled so much timing out of it. best case scenario, they pulled a lot of timing just to be a safe daily and to save the trans (supposedly it's built, but no proof makes me assume it's stock) worst case scenario, the engine is hurt so they pulled a lot of timing to try and hide it, so i changed the oil tonight and am shipping off a sample to blackstone Labs.
Also, the owner in which i got the car from, paid a shop to install the new summit pulley, but the shop did not pin the pulley to the crank. the previous owner (not the guy i got it from) was the one that modded the car, and initially the pulley was pinned, but the shop did no re pin the new pulley, so now i've got to take care of that sometime soon. other than that, car doesn't have any major issues, speakers sound like shit, and i have to order a new wiper motor. overall, i think i came out like a bandit on the trade, since the SC kit alone cost almost what my car was worth.
sorry for the shit pics, working 2 jobs currently has me very limited for time.
[chapter]Blackstone Results[/chapter]
[chapter]Water Pump Failure[/chapter]
[chapter]Windshield Tinted[/chapter]
[chatper]BT Cam Ordered[/chapter]
[chatper]Tear down Begins[/chapter]
[chapter]Built 4L60 Acquired[/chapter]
[chapter]She lives![/chapter]
[chapter]New Blower - TiV1 / New Fuel Rails[/chapter]
[chapter]Money shots and vents[/chapter
https://www.thechicagogarage.com/threads/supercharged-c5.162004/post-3947333
[chapter]New heads - PRC 2.5 243 [/chapter]
[chapter]Slight problem with the diff[/chapter]
[chapter]Putting everything back together[/chapter]
Multiple posts after this one
utryd2
Posts
4,235
North Aurora
Congrats. If you want to upgrade the suspension to c5z stuff let me know. I have shocks, springs, swaybars, end links and lowering bolts. They have about 33k on them.
TS
TS
ldyzluvdis06
ldyzluvdis06
Supercharged C5
Posts
6,052
Jacksonville, IL
buying a modded car, definitely saves money, but it's proving to be a headache trying to figure everything out.
I had a friend log it for me, and it has 0 knock which is good, but with how low the timing is, i'd hope it wouldn't knock. lol. but we saw 11 lbs of boost which is high for the standard 3.8 pulley that comes with the kit. so i pop the hood and realize it actually has a 3.4 pulley on it. upon doing some research, it seems as if most people run race fuel or meth on a pulley that size. so now i need to figure out what size injectors i have (standard kit comes with 60lbs but options 80lbs but i don't know how to tell the difference between the two) and i need to figure out what kind of fuel pump im running. because people with that small of pulley are also deep into the 500 low 600 hp mark and running low 10's which this car definitely is not. i am going to install a wideband tomorrow and see what kind of fueling i have.
also, i received the results back from blackstone, and im kind of worried, lead was high, but i tried to find someone else sample to compare mine to theirs as blackstone is comparing it to a stock ls and not a boosted ls. they requested i send in another sample in a few thousand miles.
Posts
185,646
Did you buy the vette from a person or dealer? Seems odd the previous owner wouldn't know the injector size, tell you what pulley was on the car, etc.
jason05gt
Posts
14,150
Naperville
Go through and do cheapo maintenance stuff for piece of mind. At minimum throw in a new fuel filter, buy new colder plugs, and make sure they are properly gapped. You could get the injector cleaned and flow tested cheaply.
2QuikTA
Addict
Posts
874
This is why I won’t buy modded cars. I know it’s more expensive in the long run to buy stock and mod it myself, but stories like this or copperpots make it worth the extra. You just never know who did what and how well.
TS
TS
ldyzluvdis06
ldyzluvdis06
Supercharged C5
Posts
6,052
Jacksonville, IL
as boostedguy said, the person i got the car from didn't do the work, and didn't seem to know shit about cars. i think he bought it just to say he had a supercharged corvette. i tried carfaxing to try and find previous owner (that did the work) but i couldn't come up with a name.
i have a plate number from when he dynod it, but don't know how to figure out owner from plate. also contacted weaponX hoping they would be able to go back and get me owners name but that also didn't work.
10sec
Posts
25,132
You usually don't dick around getting your cars in order, so I'm sure you'll have it sorted out in no time. You'll have extra time to remove that stripe down the middle too. :s00ls:
