🔧 BUILD Ford truck 460
Poor decisions arr my stock and trade as many of yew know.
I've had it just as long as the Cressida.... used it to flat tow the wagon back from El cajon California up Route 66.
Colorado Ranch truck for the first part of its life only ever seeing shade underneath a tree.
I picked it up from the third owner in trade for a bunch of work on getting an 91 f150 roadworthy to take over hauling garbage to the dump.
I've been collecting crap for this thing forever since before I left California where I snagged all of the Driveline and suspension from a 79 F350 that I really wish I had been able to tow back here with me.....
That gave me one ton disc brake front ttb suspension... with fresh kingpins as well as a 3.55 Dana 60 for the rear with 1 ton Springs all around to replace the 3.73 Dana 60 in it.
Some years ago I scored a pull out from an '89 f super duty, a 460efi with the oil to air cooler and a ZF5 speed trans.
I have the harness but no computer but I figure I'll just run it on a 3800 PCM so that I can make plenty of power.
Anyways on to the photographic story....beginning with where its been staining the driveway rust red....
I did have it running and I got it to move a couple of feet before it stalled and would not start without fuel being sprayed in the carb.
Either the brand new old fuel pump is dead or the carb is plugged.
Either way the 390 Fe is going to the side of the road if no one wants it.
It's about time I got around to this thing.
With a tailwind I was able to get 8 miles per gallon with the 2bbl 390fe, except for when I was coming down the mountain on Highway 8 out of California where I managed to get 20 miles per gallon cuz I left the engine off for a really long time.
With the overdrive gear and the taller rear end I know I should be able to do 12 to 16 like most 88-95 F-superduty's can do....
One thing I learned while I was in California is that the 460 guys would kill power to the four injectors on the bank without the oxygen sensor when they were on the highway for better fuel economy.... at which point you're driving on a 3.8 L 4 cylinder lol
At that point I think I should be able to at least eke out 18 miles per gallon.... with a Tailwind
32,652
16,133
I had type H on the shelf! So I used it and 4 other bottles to fill the trans, more room on shelves now!
LOUD startlingly so. I didn't expect it to fire so easily with just a cap of 2 stroke gas lol
Running my fireball hi6, perfect blue white spark across an 060 plug. Gapped all the autolite coppers to .045 like oe....probably coulda opened em.
Oem Motorcraft numbered wires ftw, coil wire is a ford racing sbf wire :rofl:
32,652
16,133
Crap. I'm missing one of my kingpin wedge bolts, hopefully it under the shelf/d60s where I can't see it.
Studs are too short for my Alcoa's. Rotors are new old units, .030 under full thickness.
Have all my seals and bearings, one grease cap missing.
:fu:
Kingpins need a little cleaning, new old knuckle bushings are dirt covered from the grease, so lots of cleaning.
Rockauto.com has a bunch the stuff I need on clearance.
The old parts are really getting hard to find.
The left inner tie rod end for the 7/8 thread 4klb axle is a damn where in the world is a Carmen sandiego game.
I feel old
