MEATeorite
Pulled a beef round roast out for tomorrow. This is something we never know what to do with.
Suggestions on smoker or grill, can I do burnt ends with it?
Ive never done a round roast before. The weight would determine for me whether I'd inject it or not. If its less than 3 lbs, id inject it. There's really no downside to injecting it IMO.
I like my beef smoked around 250-275 with a pecan or hickory till around 160ish internal temp, but im okay with going a bit past that if it hasn't developed enough bark. Then i wrap with aluminum foil and add beef broth, and a little bit of Worcester sauce. When i add beef broth i pour enough over it to absorb it, give another 30 seconds and add a bit more. Then push to 205 internal temp and rest for atleast an hour. Last brisket i did i rested for 4 hours, granted that thing was huge, but my opinion these cuts with a lot of connective tissue and fat really benifit a lot from it.
When you open it up to serve, something i do is check and see how fragile it is after rest, just before serving. If you think you can get it back on a grill without falling apart, i like to sear it 5 min a side. It'll firm up the bark and not ruin anypart of the rest.
If doing burnt ends, id suggest cubing at same time as before, 160ish internal temp or when good bark developed. Instead of wrap, cut and cube, put in foil tray. Add beef broth and a little Worcester sauce to the pan, cover with foil. Id do enough beef broth to keep moist, not so theyre submerged. As far as cook time for burnt ends id periodically monitor the texture of them. When they compress kind of like a sponge. that's when i add BBQ sauce to the pan and give it another hour of cooking. Some people add a dusting of brown sugar or dry rub, i normally just add a couple cracks of black pepper because BBQ sauce is normally sweet or complex enough for me, and i like the bite black pepper lends, especially to beef.
Hope this helps. I'll definitely be interested in how it goes.
