It's soo trueThey always run best right before they blow!
G'luck with the build!
You'd need timing cover gaskets, oil pan gasket(if it has one), front main seal, water pump gasket, intake gasket, valve cover gaskets, etc.
Go on summit racing and see if they have an overhaul kit for your car. Or napaonline.
Yea I looked too. They have everything separate it looks like though. $45 for intake gaskets!I looked on summit and I didn't see anything all encompassing
Call mr norms and see if they sell a gasket "kit"
Ew....I wish I had monies to build a motor...
I can live vicariously through you
you're an accountant mark..
Here is the ever growing list I have so far. Everyday I find something else that is needed, so it's by no means comprehensive. I'm putting this out here to see if anyone can think of something I haven't found from my research.
Fuel pump
60lb injectors
8 bolt flexplate to match the 8 bolt Cobra crank
oil pump
ARP main studs
rod bearings
rear main seal
head gaskets
head studs
I'm sure I need more gaskets, but the only ones I know of right now are the rear main seal and the head gaskets.
