• 🚨 TCG is experiencing a case of the Sundays. Working on a getting things running faster again. - Mook
Chevy Express 3500 tuning
pdalach
Jul 26, 2019
41
3
My 2500 pulled 4k without much of a problem either. This guy likely has an extra 6500lbs though with all the extras.
Plus, what's the profile of your travel trailer? I absolutely hated pulling my 5000 lb enclosed trailer with it. Even behind my powerstroke, it still pulls hard as hell due to the wind resistance.
I am pulling a rockwood roo 233s. But I don't think I'm adding an extra 6500lbs worth of gear in the trailer + van.
But I can definitely vouch that my trailer is much worse in the wind. My last trip, going down a decent incline into solid head winds, I had to hit the gas pretty hard to maintain speed.
EmersonHart13
54,264
22,481
Only way to know is the scale...
GTPpower
6,358
9,769
Nebraska
That thing is going to pull hard. It's bigger than my enclosed trailer. I doubt you have any problems, it's just a lot of surface area you're trying to move through the air.
Outlaw
19,611
16,097
Johnsburg
That is a really good question. I'm not sure. I don't think the brakes. At the least, I can engage the trailer brakes and get good grab from them.
The trailer could bearings could be seizing. I'm not confident I know how to test that.
Next time you’re on a trip get out when one of the minions has to take a leak and feel your hub. If it’s hot you’ve got issues. When I’m towing it’s literally a habit whenever I get out of the truck to feel each tire and bearing on the trailer.
NO PUKESTERS
95,888
For the record, I have seen it more than once where one of these 2500/3500 vans had a different engine than the vin decoder/ whatnot is saying. Are you SURE it’s a 6.0?
Well things just got interesting
Outlaw
19,611
16,097
Johnsburg
Disregard. I went back and saw RPO code for LQ4. To me it seems like you’re down on power somewhere. 3.73 to 4.10 isn’t that big of a difference to overcome. I literally towed a mini excavator with my 320,000 mile Yukon a few weeks ago and it just chugged along.
To answer the head casting ? Yes, you should be able to. But the vans were weird. They kinda got a melting pot of bullshit.
pdalach
Jul 26, 2019
41
3
I jacked my trailer up yesterday, and the tires roll freely.
I also looked into checking the inline fuel filter...it doesn't have one. I don't know yet how to check the filter in the tank. My next step is to pick up a fuel pressure tester, as I think I've finally identified the fuel pressure test port.
My mechanic is on vacation until the 12th. So, I won't know the cost of converting to 4.10 until then.
I do think the enclosed trailer is a problem...the effects of wind resistance, I think, is just something that doesn't get well represented in the "tow capacity" of a vehicle.
