That’ll happen when you can’t drive properly.
In all seriousness, do you know why all clutch fluid turns brown/black on all hydraulic clutch vehicles when it's in a sealed system?That’ll happen when you can’t drive properly.
It boils and you retain the water, breaking the fluid down.In all seriousness, do you know why all clutch fluid turns brown/black on all hydraulic clutch vehicles when it's in a sealed system?
I dont believe clutch fluid can get hot enough to boil like brake fluid.It boils and you retain the water, breaking the fluid down.
Is your clutch like near your exhaust?I dont believe clutch fluid can get hot enough to boil like brake fluid.
A have read that it's from the rubber seals breaking down into the fluid. Not sure if that's true or not.
I’m mechanically inept. You’re asking the wrong guy.In all seriousness, do you know why all clutch fluid turns brown/black on all hydraulic clutch vehicles when it's in a sealed system?
I actually used the advanced ranger method.Seal and rust particulates are kept in suspension but still settle into the reservoir bottom and get stirred up with new fluid.
I usually wedge pedal down and use syringe to suck n squirt to agitate and extract that crap, fill nsuck n fill n suck n fill an then release pedal to blow anything you got into the orifices into the res for one last suckout before filling and flushing the lines/bleeding.
This is the way
How have those things been long term - when not fucked up by retarded owners?2020 3.0 Baby Max towed in. 'water in fuel'
Nah, they 2 stroke mixed Def in the fuel lmao
Post the before too. Looked like shit and now looks all nice and fancy. How'd the new brake work out for you?View attachment 196031
Install yesterday
Brake worked great. Don’t have room for it in the van with all the crap I had to haul. The only metal work that needed to be done for this job was a small transition between the old plenum and new A coil which is easily site fabbed with hand tools anyways.Post the before too. Looked like shit and now looks all nice and fancy. How'd the new brake work out for you?
Might end up giving you a call sometime to work on fabbing up a new intake for my furnace, really want to put an intake/filter combo in the wall and tie that into the system if possible.... The entire area is really cramped though is the hard part.Brake worked great. Don’t have room for it in the van with all the crap I had to haul. The only metal work that needed to be done for this job was a small transition between the old plenum and new A coil which is easily site fabbed with hand tools anyways.
