"OHHHHH you mean this stalk isn't the turn signal one?!"Set up a camera inside to make sure the wife isnt using it just to mess with you.
you assume she uses a turn signal. HA!"OHHHHH you mean this stalk isn't the turn signal one?!"
Exactly, she isn't, she's using the washer fluid.you assume she uses a turn signal. HA!
My offer is $35,002I'll give him 35k for the vehicle and deal with the washer fluid leak myself.
Well for different reasons.
You're cant believe youre still talking about it because its not fixed.
I cant believe were still talking about it because who really cares that it loses some?
When the wife says "it's not spraying any fluid..." top it off....
I literally never check the fluid.... It gets topped off with an oil change, then I add more if I spray some fluid and none comes out. It's never been a safety issue.
C'mon now. Is the wife going to drive through a fountain of ink thats going to coat the windshield and she wouldnt be able to make it home?
I use the washer fluid in the GTI as needed. Probably more often than needed. I like clean glass. Even with as much washer fluid as I USE in the GTI, when I fill it up, it's 1/2 cup maybe. A cup in the wintertime.
Never a whole gallon. Multiple gallons. yes, it's my OCD, but it's also an new (well 1 year old now) expensive vehicle that shouldn't be leaking ANYTHING. It's the principle of the thing.
Agreed.
Smoke it, dye, do it yourself at this point since the techs haven't found anything obvious. However, it could be fucking gay and be a connection in the headliner/tailgate slightly leaking... had that before.
Give the washer fluid reservoir to blue-sun so he can hold some more.Maybe I need to re-think smoothing the engine bay in my Cobra because I wont have a washer fluid reservoir anymore.
I said tape the sprayers and try it out and then smoke the system on like page 6 sooooo
That's what I would've done. But I'm no dealer trained tech
Just wanted to fill that, so when I closed the lid, it would be 100% full.The pouring it on the lid....
I'll recheck it in a month and not require a top off... as mine doesn't leakyou missed some
