I want to do a joke and just spray the hose under my hood, but my luck I would screw something up trying to be funny.
Wife just ran out to Target, confirmed that ADAS is working properly. I also checked the washer fluid when she got back, car was driven maybe 5 miles since yesteday.
Jimbo
Remember when getting non OEM glass only meant your HUD might not be as sharp?Just asking because it can cause issues. Example. My friend had a non oem windshield installed on his Pilot. Now the brake warning constantly goes off on a hilly road and the lane keep assist isn’t what it used to be. All related to that front camera near the mirror not calibrated or the non oem glass causing optic issues.
Yes I doRemember when getting non OEM glass only meant your HUD might not be as sharp?
Leaks washer fluid into the cabin.Now the windshield seals might leak
Had to fill the washer fluid yesterday with about 1/4 gallon of washer fluid.
Also:
it's been leaking out for months. She did not use it, per her.So.... did it leak out or was it used to do some washing of the windshield?
Correction: They replaced a kinked hose. It still leaksThey fixed it and still leaks? [emoji38]
Maybe this ST thingy fancy and they using the washer fluid for meth injection. Tell her stop going wide open throttle so much to see if fluid level stays high.Correction: They replaced a kinked hose. It still leaks
Unreal....Correction: They replaced a kinked hose. It still leaks
Let me make sure it's clear.If youve never located a leak are we sure its leaking ???
Let's be correct in our terminology here, it is consuming washer fluid for an unknown reason.
