This is probably my favorite mod and I've hardly used it yet
I can't tell what is going on
the red wire goes to what controls the line pressure in the transmission, i ran it through a switch on the dash so when i flip the switch it defaults to max line pressure, it helps tighten up the converter due to flooding it with more fluid than normal, since zzp stalls were not really made for 5-600wtq mine flashes way higher than a 3k stall should and I think its costing me mph on the back half, and it shifts hard as fuck and thats cool too
im not sure that the pcm can command pressure as high as it goes when you just turn off the power to the switch, supposedly the zzp drag car just has the wire cut off to the pressure control, and the prj red drag car has it hooked to a switch like i do, i imagine if it could be controlled the same through the pcm they would do it that way since they are both very smart with tuning, i however am not lol so i dont know this just seemed easy
the relay is grounded to the body in the wheel well area, i hooked up an amp meter to the hot and ground and watched the voltage at the pump and its solid as a rock, i flip floped the pumps to opposite power wires and the shot one is still shot lol
Found a major contributing issue to why this car stumbled when attenoting to go into boost. Stock gap ftl, regapped the plugs and it's much better. Need to get colder plugs.
Part throttle it runs like a banshee but full throttle it falls on its ass. Really need to replace the wideband sensor and get a gauge to see what the A/F ratio looks like.
there's a pcs current table that would let you turn off current flow based on tq calcs
fuck sheetmetal grounds
hows the tq managment and maf failure rationality table on that heap?
