The ULTIMATE Coyote vs. LS3 thread.
Dasfinc
Ready for the EVlution
Sep 28, 2007
20,919
1,321
Wheaton, IL
I'm still lost. :rollpicard:
Coyote Engine - Based on a motor first put into production in 1992 that had 230hp, and now puts out 414hp. It uses 5 liters of displacement (the area that the piston essentially travels through) and lots of technical wizardry to make power
LS3 - Based on a motor first put into production in 1997 that had 310hp, and now puts out 430hp. It uses 6.2 liters of displacement to make power.
Okay.... that makes sense. I feel smarter. :hsughwiggle:
redevo58
401
A top fuel dragster makes 16 HP/ci and 1000 hp per cylinder. If that didnt mean anything it wouldnt do 300 mph in the 1/4.
get out of here with your ricer math! What he was trying to say is something along the lines of this "i dont care if your 5.0 makes 82.80 hp per liter,Im gonna use my with my bigger, badder, more powerful 7.0l 505hp 427CI LS7 PUSHROD:pedobear:, to F up that junk ass mustang six ways from sunday!
T
Typhoon
Are you assuming that no matter what the displacement the power production is exactly the same?
Yes. According to his statement if they didn't make 16hp/ci then they wouldnt go 300mph. What if the size of that motor went to 800ci instead of 500ci yet they both make the same power? HP/ci goes down but they will still go down the track the same. (This is course assuming the physical size of the motor and weight stay the same). At the end of the day it just matters how many horses you have.
Pressure Ratio
20,517
12,426
Glen Ellyn
Nom!
Stock motor, tune (not a dyno tune), T56, 3.73 gears (needs 4.10s as it just shifts into 4th right before the traps), long tube headers and 3" exhaust. 11.14 @ 124 so far.
I would slap a Vortech on this and have a nice driver.
Pressure Ratio
20,517
12,426
Glen Ellyn
Here was how I am thinking... 8000 hp in a 1 liter engine is far superior to 8000 in a 10 liter engine. It takes more to get power out of a smaller engine N/A. This is exactly the case with the 5.0 and LS3.
Ask yourself this......How would it make power? What kind pf power curve would one have versus the other? What kind of rpm would the smaller motor need to make the same peak power? And so on.
Pressure Ratio
20,517
12,426
Glen Ellyn
Wow Pratt... that didn't take long for that dude to accomplish at all! Awesome build.
FRPP sells a conversion kit including simple wiring harness, relays and PCM. Kurgan Motorsports took a running 90s couple with a pushrod 5.0 and got a running coyote 5.0 motor in the car in under 5 hours. I think there was three guys. This was done at the Ford show in Carlisle Pa. Great kit for sure.
