Pinion Seal Leak
PETSNKE
DRIVEN
Well, after taking my car out for the first time this year I discovered a pinion seal leak on the rearend. I had a Torsen T2 w/gears and bearing kit installed 2 seasons ago. I'm thinking of just replacing the seal myself and skip the whole crush sleeve and pre-load process, just count/mark the pinion nut to put it back in the same place.
What do you guys think? I never done it before.
CREJoe
Chassis Builder
If the pinion seal is leaking after only two seasons, something else is wrong. I wouldn't just put a new seal in it.
Aron
Not recommended. You shouldn't re-use a crush sleeve. In fact, while it's apart why not replace stupid crush sleeve with solid spacer? Cutting corners to save time and money can cost you more of both in the long run.
PETSNKE
PETSNKE
DRIVEN
That's what I was thinking too, but there are mechanics that swear by the seal only method.
I bet that plastic spacer behind the pinion flange that I melted when I removed the drive shaft flange bolts tore up the seal. Sucks, because I told the installer to replace it, but they forgot and said it would be no problem after they already completed the job.
CREJoe
Chassis Builder
There is nothing wrong with the "seal method" but you have a compounding issue. If you put enough heat into the flange to melt the plastic, that's probably why the seal went south. Heat travels very readily through materials that conduct...like steel. I wouldn't take it back to that shop if that is the advice they dish out. You can bring it to me and I'll get it set up right for you.
Joe
Dana
Bluesmobile
Ford offers a method to replace the seal only in the service manual that involves taking drag measurements before and after the seal replacement to allow you to tighten the pinion nut to the same load as it was before.
I've had good results following this procedure.
