My misfire from byron is a chunked piston
Angus
11,799
873
HHI, SC
So I finally had time today to check the car out since it started misfiring after my last run at byron last weekend. Basically, I chunked a piston. :sad:
I pulled the plugs and they were looking like this:
Then I pulled this one (second cylinder to the firewall, pass. side):
I look into the cylinder with my flashlight and see a chunk missing along the edge of the piston head, plainly showing the piston rings.
Now I don't know what other damages may be in there, but I could see the cylinder wall where the chunk was missing and there wasn't any scoring, thank goodness, but who knows what the head looks like...
I also checked my turbo and it spins very freely and makes no noises so I don't think it got hurt.
Now my first step question is can I just all new plugs in and put everything back together and disconnect that cylinders injector and coil? I need to be able to move the car around the driveway and possibly get it to a nearby shop. I did drive the car home to Geneva from Byron like this... What do you guys think?
Oh and what causes this?? :dunno:
hellraiser319
Hellraising since 1986
May 17, 2010
1,323
West Bend, WI
Personally, if you need to limp it anywhere, stick a magnet down there and check with a flashlight to make sure there are no chunks floating around. If you disable the coil and injector, it will run like crap, but it will run. I wouldn't personally drive it like that though. if you keep that cylinder live, very low revs and you should be fine, if there is nothing in there, damage has been done unless more piston crunches away.
As for what happened in the first place... idk, only thing i can think of is valve float and it bounced against the piston? bad wrist pin? worn out piston and stress fracture gave way? I guess, at least you found the problem, well part of it. Sucks to hear though... :(
greasy
36,959
29,100
perfect time for a 4v swap :pedobear:
This. 4V swap + turbo = new fastest TCG vert stang. :jg:
this is why you dont build 2vOHC mustangs.
You guys are flat out misinformed. Just because a Mustang is a 4V does not make it less prone to piston failure. Now if we are talking about an 03-04 Cobra 4V, then there is a difference. There are fast 2V's making 900 RWHP with the same amount of money into them as 4V's.
Why would Angus switch to a 4V? He would have to buy new heads, upper/lower intake, computer, etc.... Take that money and build a solid short block and boost the shit out of it. I think Blackbeard will be shutting some people on this board up in the summer when he is making some serious power with a built 2V.
25,951
5,836
I really think you're seeing something else, 99% of the time the piston chunk would have gotten caught up in the turbo, and the plug isn't smashed. Engines don't nicely close the gap, they SMASH the shit out of it. I think the gap was too small, it got REALLY hot when you ran at Byron, closed itself, and made you think your junk was busted. Put another plug in and go beat on it. :dunno:
Mike K
13,214
2,586
He said he saw a chunk of the piston missing. I've seen both. I've seen plugs that looked like they had been through war and other plugs that just looked like they had been gapped shut. There's no protocol that the plugs follow.
If it's anything like a 3800, pop a plug in it and drive it for another 20,000 miles. :jg:
For moving it around you should be fine just tossing another plug in it.
Fish
From the quiet street
40,585
7,998
Hanover Park
Fish
I should have been more specific and said termi motor. Would that make me misinformed then? :ford:
Why NOT switch to a 4V? Seriously, besides money, why not?
greasy
36,959
29,100
because for the 19,000 sticker price of the car.. he should have gotten an 03-04 cobra to start with.
ive been around quite a few high-powered 2vs... they almost always fuck up around 380whp-450whp depending on application.
my SHO can handle more :rofl:
Well it is too late to go out and buy a Cobra now, so the point is moot.
Blakbeard has been running close to 400 RWHP without major issue for over 4 years now on his stock bottom end 2V. With his block being built he should be seeing over 500 RWHP. Angus was at that HP level, but he was making a sick amount of torque.
Angus build your bottom end and boost the shit out of it.
32,648
16,122
Probably, but still better see what you are working with. Easier to make a decision that way.
:werd:
there wouldnt be a whole lotta difference and he may not want to spend the $ for a 4v...its a turbo car, they do damn well with heads that dont flow gobs of air.
teardown and inspect is the best recourse, the ring land is pretty brittle so it can get shattered pretty easily and the bits leave the chamber relatively unscathed, ive also seen em get pinched in the valve seat and have the valve head snap off the third startup after....
if your planning on havng to drive it around to move it for a while before repair ya might want to do a leakdown test before just popping in the plug and driving it. esp if you plan on reusing the block and other components.
i can tell ya first hand there's nothing worse than telling a guy that his sprayed 396 looks fine, all he needs is a piston, and then calling him 2 hours later and informing him his head is now junk.
