Ive searched without any huge success....anyone found a way to make their factory 03 cobra mach 460 sound system work well with ipod/mp3 player...of course im familar with fm modulated but have read bad reviews..anything else???
Spent quite a while on the phone with the people at www.pie.net and then went and pulled my car out of storage to confirm that they do not make anything compatable with the 03-04 cobra mach 460 6 disk factory cd player....so either their wrong or you are...can you tell me if you did this??
It says on their site it will not work with the Mach 460, but it does, BOOM: http://www.chicagolandmustang.com/forums/showpost.php?p=715093&postcount=3
I installed this on a friends 03' Cobra, took 25 minutes, sounds awesome.
In the PDF I have in my post linked above, just use ShelbyGuy's instructions for constant power.I use the PIE adapter. It works pretty good. I think the problem with 'incompatibility' is the power source isn't there on our stereos so you have to wire it into your hard line. Don't wire the power to your foglamp switch though >< supposedly defroster is the way to go.
Only complaint I have is unrelated... I get nasty electrical noise down the line when I charge my zune or phone while I'm trying to listen to it at the same time.
Oops, didn't know you had to be logged in to open it. I attached it below, its just a few of the posts from that thread I thought would be helpful.pdf is at the bottom of the cmc link....must be a member to open/view.
Smartest thing you can do is ditch the entire Mach 460 system. You will be much happier with a standard audio system than with the Mach 460 nightmare.
This is retarded. The 03 unit will work with the PIE unit. Its the Machs with the SAT button that wont.
Do you want the auxillary connection or an ipod connection? Let me know and I will tell you which one to order and can help put it in.
This is not that difficult. The incompatibility is wrong. My cd changer still functions with this adapter.
This is the only unit you should look at if you want to run an aux connection to the mach. It works flawlessly in my car.
Jesus.
