Lowering a GT500
My sister's bf asked me to lower his GT500. He bought the FRPP lowering springs. I have lowered foxbodies and sn95s, how hard would it be lowering his car compared to the cars i've lowered? Any specials tools or tips is appreciated. Also I don't know if they changed the suspension at all in them since they came out but his is an 07. Thanks
skyhighsd
auto mofo
sideways
yes, im an ass
yes, adjustable panhard bar and some caster/camber bolts for the front end and you'll be set. i had a buddy do them on mine while i was at work. took him no time at all
skyhighsd
auto mofo
If the camber bolts didnt come with the springs Doug dont get unless you need them after they try to aglin it. I didnt need them to get into specs on a laser rack, some do but most do not need them.
sideways
yes, im an ass
i needed the bolts cuz my drop was 1-3/4" all the way around and i was getting some kinda bad wear patterns on the front tires
VNMOUS1
Light fuse, get away.
Thanks guys
Larry did mine at Speed Inc using the FRPP lowering springs. They give it just the right drop. Used a Steeda panhard. They suck. Do a BMR. Higher quality.
Used Steeda caster/camber. They're fine. BMR and Maximum also have them.
My alignment is perfect. Tire wear is as it should be....lots on the back :)
Makes it look like this.
Good luck.
bj
SonicBlues92
Cobra Lover
That gt500 looks sick with that drop. Also like the painted side mirrors.
VNMOUS1
Thanks. Gonna be interesting to see if I can shoe horn these big-ass wheels and tires under it with it lowered. I'll find out in about a week. It's going to take a rear sway bar relo, removal of the bump stops and the dust covers off the D-Specs.
I may have to swap springs and go a little higher. The tires are 28 x 11 x 15. Stock is a little shy of 27".
bj
SonicBlues92
Cobra Lover
bj
Damn those are some fat ass meats. You gotta post a rear shot when you gets those meats on.
