I'm gonna hold onto it for now!
That sarcasm I sense?
No, sarcasm here. I would hope to have a rocketship in the next couple of years with the build that is planned right now.
cam arrived at FAST today!
need to decide whatever all other parts I'm going to pick up and start getting back into the garage. the TA can't keep sitting around... although the pull to the GT is strong!
Here's the Q currently:
Head gaskets. Felpro PermaTorques? Cometics? 6.0L? LS9? So many options! Found some feedback, but wondered what yall had to say on the topic.
Yep, it was a double roller that failed. I went to a c5r chain now. Supposedly, there isn't a single known instance of these chains failing.
Cam specs? I can't go just blabbing that info!
So wait, you are going with the 317's with the cathedral style port heads? If you did, you will get more power out of those after porting than any aggressively ported L92 heads. LS9 gasket is the ticket nowadays.
Don't know if you had seen this thread on ls1tech but it is a good read after the L92's were pulled off.
http://forum.grrrr8.net/showthread.php?t=19766&highlight=AFR+230
Decided against L92s when I saw all the other stuff I would have to change or adapt to work with them. KISS!
2 slow, not broken cars to drive anytime, beats 1 fast car broken more than it's not!
boooooo, will you tell me if i tell you my plans for my TA this year?
