Let the 2013 build begin!
Eagle
Nemo me impune lacessit
63,909
4,744
Woodsticks, IL
Start up funds in hand... now to get busy!
Replacement Heads (destroyed my old valves and seats)
Replace all destroyed covers and fab work for oiling
Re-gasket and bearing the motor
While its down that far, might as well cam it, DUH!
Build thread starts as soon as parts start showing up!
Chester Copperpot
Unvaxxed Untermensch
39,566
40,748
Blanco el Norte
What size block you have? If it's the stock 346 the LS3 heads won't work unless you get the ones made by Mast Motorsports. http://www.mastmotorsports.com/2010/product-view.php?cat=Cylinder Heads - Assembled&id=360. You need a 4" bore or larger and the LS3/L92 heads will work.
The LS3 and L76 intakes are mechanically and functionally identical except the LS3 MAP screws in and has a different wiring harness whereas the L76 MAP sensor will plug and play into LS1/2 harness'.
