I only like the Shlebly GT500KR.....but all in all it is still a mustang.....a lot faster but not impressive....Coming from someone who owned 4 of them! I perfer fox bodies, the 99-04 body styles.....Will be waiting to see what SVT does now...
It's pretty nice, but still not impressed.
Well played Ford, well played. Now we gotta see what the Z28 brings lol.
Why are you relying on a Z28 model? isn't that usually below the SS models?
Curious why you aren't impressed at a factory 412 hp GT. This car is superior to all Mustangs before it when you look at the overall package. I am curious what SVT has up their sleave for the 2011 GT500.
The Z28 goes up against the GT500. The GT500 in 2011 will be dropping weight due to the aluminum block and a couple of other changes. GM better put the LS9 in the Z28 because the 6.2L LSA won't cut it against the lighter GT500.
The Mustang might be a little more nimble and be rocking more under the hood but the Camaro is just rolling sex. I'd rather have the Camaro and pop a couple sway bars on it and a set of headers. The Mustang certainly isn't bad looking, just not as sexy as the Camaro in this guy's opinion.
The weight.
At what cost, will this 412HP mustang be at?
I truly believe this thing will weigh 3600-3700lbs, depending on options.
While it is impressive, for the money I am sure it will cost, if you want performance, you are better off buying a used GT500, or spending a bit more and getting a new GT500.
While price is all speculation, don't you agree this will cost more than a new S197GT by quite a few thousand? My 07 was 32K factory ordered. It doesn't have a bigger motor, better internals, a more expensive and stronger trans, and the interior features this comes with. I bet this GT will be around the 40k mark, if not higher.
I don't see the point in spending that much on a GT, when the MSRP of a faster model is a few thousand away. To each their own.
Not knocking this GT at all. I will probably change my mind and shut my mouth when I am proved wrong, and the price is right, and it becomes a proven platform once people start racing it.
I bet the 2011 weighs within 25-50 lbs of the 2010. The guys that have given reliable information about the Coyote also say the price isn't going to be a drastic increase.
You are comparing a new car against a used car; that's not apples to apples.
25-30lbs?
So, .4 Liters bigger, a bigger trans? Dude, lol.
You do realize the trans alone is probably 40-50lbs, not including the heads and cams, plus the bigger block?
You are speculating.
The 3V is an alum. block & heads, so the there will be little or no weight gain there.
The transmission is a Getrag 6 speed (MT82) not a Tremec 6 speed, so who knows what it weighs.
Like I said, the guys that were correct with the Coyote are stating that weight won't increase much (if any).
If the MSRP is close to 40K, why buy a GT, and not buy a GT500 for a few thousand more? Since, MSRP on a GT500 is around 45-46K, that is a better platform.
I agree.
It is speculation, however, doesn't this make sense?
I'm gonna go with a sub-$30,000 starting MSRP for the new GT, like $29,995, just for marketing purposes of being able to say it's less than $30k.
