If the next one fails the same way, print an empty box, just the walls, and set it to the same height as the dog
Oh wow. Usually they last longer then thatalready burnt up the fan on the right side of the hot end. Wee!
Guess it’s time to upgrade some parts for this thing if I’m going to buy on Amazon.
itll go like this.....
Month 1-3
"why do you spend so much time fixing and working on that printer?" " Do you NEED to upgrade it?" "Why are you printing that stupid shit?"
Month 3-6
"You fixed that by printing?" "Oh that can be pretty useful."
Month 6+
"Can you print me this?" "Can you fix this"
Then itll collect dust for a bit.
12+ months
"Are you going to use that thing again?"
repeat when you buy printer #2
my brother got me this shirt for XmasThis is obligatory at this point
Oh thats nice.I would recommend staying with the creality branch of marlin as it should be more Plug and Play for you although if you really want to expand capabilities you can break out into the far more advanced Marlin tree
Sd cards are iffy on all of the cheaper boards. That's why we prefer the duet ethernet boards. The monster with a rpi4 as masterblaster for the duet2 Ethernet.
Although just recently we bought a duet 2 Wi-Fi for the third "big" machine we will probably sell as people have inquired about our large format machines.
Fuck me I can't believe it has been June of 2021 since this printer really ran.I put the SKR board in yesterday. Not a bad install on the Sovol, the later ones have 2 X axis ports. They must use a different motor on an Ender3 for the Extruder though because I had to flip my wires around so that it ran the correct direction. I also don't have my filament switch nor the under chassis fan hooked up. I guess that's next. Although it definitely needs a calibration it heats up without puking out. Not sure wtf is up with my Creality Board. After I pulled it out I got it to flash a bootloader without any drama either which is also kind of annoying since I'd have probably gone that route. Doesn't really matter though I have a little printer that probably needs a board or I'll swap the Melzi out on my Tronxy instead. I've gotta get Marlin 2.0 to build first though, I'm having some problems with it at the moment.
The motors are insanely quiet compared to the stock board, it's nice. There's a bunch of new features too I need to poke around with as well.
Also something strange is I didn't see any way to set the stepper current on the SKR board.
Probably. Lol. It did look really damn smooth. They mentioned it in the comments as well asking WTF.Lol 19days.... Was that printed on the slowest, smallest layer ever?
Got my junk fixed a day or so after this and printing like a dream. Loving the garolite build plate.Officially spent more time troubleshooting than printing now.
Printer has been absolutely FUCKED since installing the CR touch.
Intermittently freezes and stops printing, won’t hold a z offset in memory, decides it doesn’t want to extrude at random times, doesn’t recognize an SD card better than 50% of the time.
I’m about two hours away from burying this thing under my work bench and being done with it forever.
