đź’¬ OT 3D printers...who has one?
Mr_Roboto
25,906
31,087
got some peach fuzz but no ball so far probably 12+ hours in.
Reactions: Turbocharged400sbc
32,643
16,111
Turns out all my headaches with the big printer are related to one of our linear rails having a slight Bend in it approximately one-third down it's length.
I've been chasing this for a while and I finally have absolute confirmation. So now we got to pull the damn thing apart again
We also use Norm to make a parts cooler for the nearus
Reactions: Mr_Roboto
Lord Tin Foilhat
60,725
56,889
Privy Chamber
32,643
16,111
Damn I want a bigger bed printer now lol
Other things begin to play a factor with big machines. We've been chasing f****** headaches with our bed levelness and mesh compensation. You see that blue dip on the mesh compensation table?
That dip right there turns out to actually be because of a very slight Bend in the linear bearing along that side of the X axis.
We are in the process of swapping out the rails now. But then maybe we will have a good mesh compensation that doesn't give us Oddball layer thicknesses
That right there is measured off of a perfectly flat piece of quarter inch mic 6 aluminum 21x38 inches
Reactions: Lord Tin Foilhat
Lord Tin Foilhat
60,725
56,889
Privy Chamber
Done. I had the line bind up at the top on the spool and fuck a layer up.
Any ideas on the texture? maybe a bit hot? I had adjusted my retraction and I am wondering of it reverted.
maybe cooling but also looks like over-extrusion. Try changing your extrusion multiplier to 0.99 or 0.98 and also verify your E-Steps
Mr_Roboto
25,906
31,087
Gotta ask I have the new printer with the bltouch and I am as a whole unimpressed. I am still having some print warp issues and I managed to break the tip off, it doesn't seem any easier than just hand levelling now and again. I am thinking about converting this printer to a switch honestly. Am I missing something here?
Lord Tin Foilhat
60,725
56,889
Privy Chamber
Sup. Picked up an ender 3 pro from micro center today. Made the mistake of mentioning it to fiancé.
“What do you need that for” followed by “the look”
itll go like this.....
Month 1-3
"why do you spend so much time fixing and working on that printer?" " Do you NEED to upgrade it?" "Why are you printing that stupid shit?"
Month 3-6
"You fixed that by printing?" "Oh that can be pretty useful."
Month 6+
"Can you print me this?" "Can you fix this"
Then itll collect dust for a bit.
12+ months
"Are you going to use that thing again?"
:rofl:
repeat when you buy printer #2
Lord Tin Foilhat
60,725
56,889
Privy Chamber
What free software are you guys using to draw shit up?
freecad for software CAD based/accuracy based.
Blender for like 3d models (think 3d figures, mini figurines)
Tinkercad is good web based for quick shapes but also pretty powerful.
PrusaSlicer and Cura for slicers is what I use mainly. If you are doing Lithophanes, LuBan is awesome.
Reactions: OffshoreDrilling
Lord Tin Foilhat
60,725
56,889
Privy Chamber
sounds like you are missing something if you broke the tip off and having issues still.
Bob Kazamakis
I’m the f-ing lizard king
85,554
45,799
Joel
They had $100 off coupons for the v2 for a while now which is wild.
Find some dumb shit to make her off thingiverse and she’ll change her tune.
I use fusion360. Free version limits you to 10 editable drawings at a time but they can be turned to read only and back to editable without issue. Only thing I’ve noticed missing from the pro version is some mesh features so far.
Lord Tin Foilhat
60,725
56,889
Privy Chamber
1st print. No idea what the fuck happened there. It’s like a section of the body is just missing. File that came on the SD card
Printing another now to see if something is up with the file or the printer. I had to walk away for 30min and couldn’t babysit
make sure your Z isnt binding. It looks like over extrusion or its not moving properly up/got stuck on a layer and oozing layers on top of each other.
Measure its height and then look in the slicer and see how tall it should be.
