2020 Ford Super Duty
Rent Free
24,552
20,568
Nowheresville North Dakota
Agreed so the I dont see how any of this is really shocking. Its what big pushrod engines do.
Yes it may not be off the shelf parts but 7.0+ ci GM combos Id be willing to bet with equal head flow, cam specs, compression, and cubes has produced the same results for what like a decade? Albeit this take far less custom work and therefore drives down the cost.
Welcome to technology, trickle down engineering, and modern design.
Rent Free
24,552
20,568
Gale banks is supposed to be doing a couple different turbo setups with it.
I wanna see what the 3.8 whipple does to a 100% stock Tremor. Lets see diesel like torque from a 7.3 with a 3.8 whipple.
Modern unopened engines have ruined us all. Just throw boost at it and send it. Then see what itll take.
Reactions: Jon01 and GTPpower
GTPpower
6,351
9,752
Nebraska
I just wanted to point this out here....this is a local guy's car. It's a zo6 Vette with a max effort NA build. The 427 was resleeved to 447, solid roller cam, etc...
This is through a 4l80e on a mustang Dyno. Max power was 605 at 7100 rpms. You can see how torque was dropping off as well.
Kensington
11,317
5,369
Engine Masters just did a 1000hp BBC NA build. Most was off the shelf parts, except for the domed pistons. Wasn’t cheap though...Dart Aluminum tall deck 578(?). I think they ran 13 or 14:1, big ole flat roller cam, but off the shelf ~90cc Dart heads, off the shelf Victor single plane, and a Holley 1050. They ran some special shaft rockers that mounted on a rail or something, never seen it before. But titanium intake valves and inconel exhaust valves. Made peak at 7200 or so, and JUST made it over the 1000 mark after some tuning. I think the were also running C16. And weirdly running a timing belt, not a chain for longevity
Reactions: GTPpower
89,593
The Tremor Off-Road Package is optional on XLT, LARIAT, King Ranch®, and Platinum Crew Cab® with 6 ¾-ft. box and 4x4.
Includes:
• 35” Off-Road Tire – LT285/75R18
• 18” Low-Gloss Black Painted Wheel
• Unique Front Springs – Ride Height Increase
• Rear Electronic Locking Differential
• Front Limited Slip Differential
• Performance Front & Rear Shock Absorb
• Power Driver seat (8-Way) (XLT only)
• Off-Road Running Boards – Textured Matte Finish
• Skid Plates – Transfer Case and Fuel Tank
• Unique Front Air Dams – Approach Angle Improvement
• Water Fording Vent Tubes – Transfer Case & Axle
• Rock Crawl Mode
• Trail Control Mode
• Tremor Off-Road Decal
• Spare – Conventional Road Wheel
• LT285/75R 18E BSW Spare Tire
• Wheellip Molding – Body-Color
the front slip could get pricey trying to add after the fact.
this thing with a locking rear, limited slip front, and the duratrackscsks, has to be quite unstoppable
$3975 for that package
makes sense at least kinda...
sport package...
$4300
The LARIAT Sport Package is optional on LARIAT F-250 and F-350 SRW Crew Cab® with 4x4.
Includes:
• 6” Ebony Black Angular – Running Boards
• 20” Ebony Black Painted Premium Aluminum Wheels
• LT275/65R 20E OWL A/T
• Body-color front and rear bumper
• Ebony Black Fender Vent Surround
• Ebony Black Painted front Grille Bars
• Ebony Black Painted Mirror Caps
• Headlamps – Black out surrounds, LED only
• Tough Bed® (spray-in bedliner; includes tailgate-Guard, black box bed tie-down hooks and black bed attachment bolts)
• Wheel Well Liner, Rear
imo you should get credit for at least those three items, since the tremor package upgrades em
FESTER665 BADAZZTEALCOBRA read these two posts above.
89,593
89,593
