2020 Ford Super Duty
BeerOrGasoline
New Lenox, IL
6.2L V8 (Gas) OHC
7.3L V8 (Gas) OHV
6.7L V8 (Diesel) Gen3
No power numbers yet.
10spd's avail on all models.
Pro Trailer Backup Assist available.
Dually's get unique grill for maximum airflow.
He's/him/his/penis
god why couldnt they change that displacement by just 0.1 :bowrofl:
fucking clickbate AF!!!!
daturbosix
Forum Sponsor
ford finally had to copy the LS. ha
lsallthings
BeerOrGasoline
BeerOrGasoline
New Lenox, IL
lsallthings
Allegedly due to size constraints, as this 7.3 replaces the 6.8 V10 as the engine for all the RVs and fleet vehicles, etc, and the manuf's were complaining it took up too much space.
Pressure Ratio
Glen Ellyn
It will be interesting to see the power numbers on the 7.3L. As well as fuel economy and long term reliability.
lsallthings
ummm the LS had a lot if similarities to the SBF. So there's that. haha
He's/him/his/penis
Like....... What? Metal components?
Pressure Ratio
Glen Ellyn
lol That. But more. The LS has more in common to the SBF than the old SBC.
Things like the bore spacing, the number of head bolts, the head bolt location, pushrod location & angle, lifter location, non-siamese intake and exhaust ports, oil system, coolant system, 5.0 HO firing order, and other things are more SBF than old SBC. It's well documented. heck, guys have installed LS heads on SBF with very little modifications. But honestly, other than having something different, why bother? lol Build an LS or Clevor SBF.
I love the LS engine family. But between the similarities to the SBF and some Mopar in the bottom end, GM engineer did their homework and came up with a great motor. They continued to improve on it over time to. They kept that pushrod motor relevant for a long time!
GTPpower
Nebraska
I'm so damn excited for the 7.3. I hope that oil pump doesn't turn out to be a nightmare.
But, the "leaked" power numbers I'm hearing kick ass.
willizm
Ho fuckin Ho!
Saint John, IN
"in block cam", in other words "pushrod motor"? I thought Ford had that superior DOHC v8 design yada yada :ford:
Chester Copperpot
TCGs Far Right Leader
Shithole, IL
Same. As long as "variable" doesn't include it's lifespan, I'm swinging hard.
Gav'sPurpleZ
Pingree Grove IL
so if a GM 5.3 takes 8.5 quarts, this 7.3 should take 11.7 qts of oil
Pressure Ratio
Glen Ellyn
It says for reduced engine height and width. Which makes sense. But how wide is it as is? A truck usually has a lot of engine bay room. So how big would it have been? lol
BeerOrGasoline
BeerOrGasoline
New Lenox, IL
no, I don't fucking care about a new mustang lol
It's not entirely for the trucks, it's whatever else this thing ends up in (aka everything a 6.8 V10 has been in the last 10yrs). So the reduced size when crammed in a Class A motorhome was ideal.
Kensington
The 6.2 makes 385/420...you'd have to assume the 7.3 would make more than that...
Maybe won't make that much HP, but you'd have to assume 500+ torque seems almost guaranteed
GTPpower
Nebraska
The v10 never got anything better than the 5R though. The new 7.3 should be awesome with the 10 speed, if I can get over all the shifting it'll do.
GTPpower
Nebraska
The V10 made 457 lb ft at 3250 rpms with something like 90% of that available from 1500rpms to 4500rpms.
Pressure Ratio
Glen Ellyn
That makes sense. But motorhomes have less space than a pickup? Being lighter and more compact is a good thing. *edit* drrr I went back and saw variable cam timing.
It's supposed to be over 400hp. The part I'm really excited about is the 500-550lb ft of torque that is supposed to be a better curve than the v10.
If it has a flat torque curve mated to the 10 speed should be interesting. Especially of the OD in the trans offers decent fuel economy.
