My sister bought a 2011 Fusion Sport with the 3.5L engine and we are having a brake issue and a engine stalling issue.
First the brake issue. The brake pedal is soft and with the engine running I can push the pedal to almost the floor before i get good pressure. With engine off I can pump the pedal 3 or 4 times and still have a little bit of travel in the pedal before it is very firm. I have inspected the brakes for leaks and every is dry. I have bleed the brakes 4 time and electronic bleed the Abs module. I’m thinking master cylinder or swelling brake hose.
Second engine stalling issue. Very randomly, always at idle the engine will just stall like you would turn the key. No sputters or rough idle. It literally just quits running and you can restart it right away like nothing happened. Lots of Google suggested throttle body and i replaced that with no change. I replaced the MAF because i had cleaned the original MAF and the issue seemed to get better but wasn’t fully resolved. No codes at all! I can’t figure it out.
Any help would be great!
