Weight reduction, cam/rockers, 3.2, e85, tune, small supporting mods should be 12s
Your/that focus is a ~300whp to high 200s car, no? What mph did it pick up in the back 1/8? Comp G will come in 3-400lbs heavier. Just doing the super rough math, L32 cars dyno'd low 200/210s at best iirc. The m90 is terrible for relative gains compared to even a crappy turbo. A 3.0 pulley on e85 with a tune is not going to net you 100+whp
1quick is right in the ~300whp as a number to shoot for full weight for 12s. Not saying its a hard number, but a good round number estimate, MPH i have no idea
Don't believe everything you read online (especially fb), you will have to go to ATCO in december with a -1000 DA to duplicate some numbers people claim lol
I don't know what to tell you.
2016 Focus ST (ST2) = [email protected] (Unleashed tune E40, Thermal R&D Turbo back and slicks, that's it) 1.78 60ft stock suspension.
I know what prevented that car from running 12's, my inlet temps were 150+ degrees in 4th gear at the top of the strip. Cars with the same mods but upgraded intercooler trap 105-106. With weight reduction 107-108. I went the WMI route and I copied another guys installation. It resulted in intermittent spraying and a burned up pump, replaced under warranty by AEM.
No offense but this has to be a mis-type or quote, 275/300 would be the "right" numbers. I'd love to see the email exchange on that particular part. Dudes livelihood for like 2 decades was/is around the 65e.I talked via email with Dave @TEP, he said the stock trans will be fine up to about 375/400 hp if in good working order. After that the input shaft becomes the next problem, then the drive chain.
