I had an 81’ atc 110 a couple years ago me and my daughter restored, I have a not running big red sitting at a coworkers house in Iowa right now just waiting on me to get the time to go pick it up as wellYou have or had an ATC right?
This one is going to be blinged out and fast as ballsYou're a fucking pit bike crackhead lol
and then the next, and the next, and the next.... I love it.This one is going to be blinged out and fast as balls
We will have the full range of pit bikes now ranging from 8-20+hp this one is about as big of a build as possible, after this I’m going to do a bit of work to the street bikeand then the next, and the next, and the next.... I love it.
It does seem pretty good, it’s not fully cured yet it says it takes 7 days to fully cure but I can wipe it with a rag and it doesn’t scratch real easy, I’m starting to think about dropping the motor and pulling the forks and just having the frame and swing arm powder coated since I’m already this far alongThis thing is going to look sick. I like that acrylic paint. Does it seem pretty durable?
I thought so. I was hoping to see a post on swapping in a pit bike motor into the 110. I have been kicking around the idea of trying. My nephew just bought a 70 with a piranha. I'd want a bigger frame but it seems more difficult to swap a 110 because of the frame.I had an 81’ atc 110 a couple years ago me and my daughter restored, I have a not running big red sitting at a coworkers house in Iowa right now just waiting on me to get the time to go pick it up as well
LOL like you're really bummed you get to make this thing even badderthis is a bummer I can’t trust that to not break since I will be racing and jumping this ol girl, so I ordered a set of bad ass rims for it and they were expensive as balls, but worth it since I won’t have to paint them now and the hubs are anodized blue
I’ve seen a bunch of 70s swapped , I don’t remember the way the engine was mounted on the 110 but I can’t imagine it’s a lot different once you get to the 125 they are vertical mounted but the 110’s are normally horizontal, I’ve seen 190 swaps onto the 70’s that would be rowdyI thought so. I was hoping to see a post on swapping in a pit bike motor into the 110. I have been kicking around the idea of trying. My nephew just bought a 70 with a piranha. I'd want a bigger frame but it seems more difficult to swap a 110 because of the frame.
Seems the sparing is off and you need to make brackets to get the pit bike motor in the right spot for the chain alignment. When you do the pegs placement put your heels in the tires if you wear a show larger than a 5.I’ve seen a bunch of 70s swapped , I don’t remember the way the engine was mounted on the 110 but I can’t imagine it’s a lot different once you get to the 125 they are vertical mounted but the 110’s are normally horizontal, I’ve seen 190 swaps onto the 70’s that would be rowdy
It was 1100 dollars I wasn’t planning on spending, but they will look bad assLOL like you're really bummed you get to make this thing even badder
I saw a guy swapping a new fuel injected crf110 motor into a 70 recently on one of the pit bike Facebook groups, it would be a super fun swap even the 140 can be rowdy I have one on my gpx that’s probably 15+ hp I’m sure the old 110 was probably only 4-5hpSeems the sparing is off and you need to make brackets to get the pit bike motor in the right spot for the chain alignment. When you do the pegs placement put your heels in the tires if you wear a show larger than a 5.
Motors going back together pretty good, I got my new cam in, looks like it’s a lot more aggressive than the other one just looking at the lobes on it, hooked up the decompression threw the new piston in and she’s looking blinged out View attachment 195242
Whenever your back up this way, I have dirt bikes from 5hp all the way up to 55hp you can try outDude, can I ride it
