After looking at probably hundreds of cases, over the last couple days, I think I finally found one that has everything I want/need.
https://www.amazon.com/dp/B07HP7FK7M/?tag=tcg21-20
Tempered glass side, rgb lighting that doesnt break the bank (because why not), built for water cooling, 5.25 bay, covered power supply for cleaner look, and as long as the dimensions are accurate, shouldn't be too tall to fit into my computer desk. (that was the biggest PITA) Not sure how cable management will be, but doesn't look it would be too horrible. Only thing is from the couple reviews I could actually find on this thing, it seems that even tho this is advertised as having a 5.25 bay, it has a bracket going across it for a 3rd fan mount, and it sounds like that will have to be cut out in order to get a 5.25 drive in there.
The biggest thing is there's mounting options for a 240mm radiator on top or in front, so hopefully I can utilize one of those positions w/out interfering w/ the 5.25 drive or anything else.
