Wiring question, what would you do?
Bob Kazamakis
I’m the f-ing lizard king
85,582
45,894
Joel
So I've been cleaning up under my dash and wiring in a radio and a tach. Both require a switched 12v source which I do have a single wire for that from the factory radio wiring. What would be the best way of connecting these two wires to this single one? Both have harnesses so they don't necessarily need to have disconnects.
Edit: taken care of. Thanks icecreamassassin
Bob Kazamakis
85,582
45,894
Joel
Yea, I know how to splice and have crimpers. I generally do this technique, solder than use self adhering tape.
SleeperLS
14,387
8,263
West of the Mississippi
Bob Kazamakis
85,582
45,894
Joel
I have an auxiliary fuse box installed in the cucv with a relay to power up when the ignition is on. That thing required more custom wiring due to not being wired for a radio and only having one spot for a key on power source (and half the fuse box being 24v :rofl:)
I ended up just using the oem key on for the radio and using an open aux connector for the tach. Speedhut has daisy chain wiring harnesses so when I get more gauges it'll now just be plug and play. I'll update my build thread soon enough.
Dennisn
229
140
I recommend adding an auxiliary fuse panel. It helps keep things clean and you don't have to hack the factory harness.
Here is what I did in my fox body. I ran a 6ga wire from the battery to an 80 amp continuous duty relay. The relay powers up the fuse panel when the key is on.
If you plan on adding more than a few things this really is the right way to do it. They make them in 6 fuse instead of twelve if you don't need that much expansion.
There a nothing wrong with a mechanical splice as long as it's done properly.
buy something like this: CirKit Boss Auxiliary Fuse Block/7 Circuits/Weatherproof (3 Constant - 4 Ign.)Details | Painless Performance
easy to add more circuits at your leisure. i've used one on the past couple cars instead of hacking wiring
[MENTION=12377]ekrunch[/MENTION] used a nice piece from Painless that had relays built in.
Best decision I ever made. I have one similar to the one quoted here except mine has 7 outputs that are switched power. All wire, relays, circuit breakers, and fuses included from Painless Performance. Everything is soldered in place and sealed too.
Highly recommended.
P40E
9,191
4,563
Problem solved that is good . But I myself wouldn't run just one 12v power to feed both the radio and tach . 12v can be split though . pretty sure it would be ok . That's just me .
With connecting wires ... if you are make shift splicing shit together like two wires into one , the easiest way is using step down butt crimps . You can even heat shrink after wards . Fuck soldering . It's a radio and an accessory , not an ecm .
Mr. SBF
Keeping it Real with Ford Power!!!
May 12, 2015
3,247
7
Kenosha County
I run my tach's 12v source into my ignition switch. Key on tach on... Never had a problem, been that way for 10 years.
I made a relay panel back in October when I added nitrous. I had relays for my waterpump, fuel pump and fans but they were all over in different spots on the car. Plus I wanted everything else to be on relays and on one board for a cleaner look and easy trouble shooting if something went wrong. Turned out pretty good for my first one and doing it on the cheap. The next one that I do for my other car will be better.
