It could have also been from the sustained stress when it was making those 1/2mile pulls.
That's what I'm leaning towards myself. Most are saying keep LS RPM below 62-6400. I was going thru the 1/2mi traps at 6600+ :eek4:
I'm skeptical.
Gives you a reason to get a bigger turbo now.
Why? Bigger is not always better for the combo. PT88 is plenty big for a street strip car.
this turbo is supposed to be rated to 1250HP... but if you can't spin it hard enough to get there.... Maybe its only good enough for smaller engines.
Dan..... is it just me or does your office have a party at least once a week?
Sorry to hear about the turbo! Glad the motor is ok!
You are not gong to see that hp rating with the motor you have. Swap to a 2.4L and you may have a shot.
I am sure it is going to be some coin and effort to get it done. Maybe a good winter project.
throw a cheap sensor on the pre-turbo exhaust and see what the backpressure is. I would be shocked if it is all that high. That wheel still flows a lot, and I can't imagine your motor being extreme in any way.
That's what I was sorta getting at
I am somewhat skeptical regarding this. While what was said regarding pressure ratio vs flow volume, and thus efficiency and wheel rpm are true, the PT88 has been taken further than what you were making on the same displacement; and with similar turbine wheels and turbine housing a/r too.
Unless someone beats me to it (pressure ratio), I am going to plot your figures on a PT88 compressor map to see where your efficiency and wheel rpm generally falls. My intuition tells me something doesn't add up, but I could be mistaken. The data will tell the story.
Do it. My understanding is that no compressor map exists for the pt88.
