Plan is to load the kid in the car tonight to burn the 93 out of the tank. Might have to stop by. Have fresh fries ready...lolWhenever you want, sweetness.
I'm running them around 26-28. They do well for me at that pressure so I haven't played with it at all. You have a nice sidewall on yours so I wonder if even less pressure will be better. Probably need to heat em up a time or two to get em nice and sticky.Not bad so far, although I haven't fully flogged her from a dig. I was initially running them at 30 psi cold and they were spinning a little, I took them down to 27 and it seems to be much better.
What are you running yours at on the street?
Straight from Nitto for the NT555RII on my Hellcat..Not bad so far, although I haven't fully flogged her from a dig. I was initially running them at 30 psi cold and they were spinning a little, I took them down to 27 and it seems to be much better.
Different tires but I used to run low 20’s on the street with et street SS’s 23ish was the sweet spot much more and they would ware weird much less and the felt squishy around curves, I still couldn’t hook in first gear though on the streetNot bad so far, although I haven't fully flogged her from a dig. I was initially running them at 30 psi cold and they were spinning a little, I took them down to 27 and it seems to be much better.
NT05R on Barney, I run 22psi
Holy shit what did you do?
Ok I need to have a sit down with you about this shit. I keep my cars pretty minty, but have never buffed or ceramic coated anything. Would like to buy some stuff and give it a shot, but need some good tips and what exactly to buy.Wash, decon with Iron X and clay towel, polish with 3D One and a Urofiber pad, 2 coats of 3D Ceramic Coating.
I'll stop by with my buffer and crank that bitch on high and hook your paint up lolOk I need to have a sit down with you about this shit. I keep my cars pretty minty, but have never buffed or ceramic coated anything. Would like to buy some stuff and give it a shot, but need some good tips and what exactly to buy.
That turned out fantastic.
So glossy. So shinny.
No pics of the owner modeling with the car. Lame.
Fucking schwing.
HC Challengers don't normally do it for me but your car looks amazing. Perfect stance, wheel/tire combo, etc...
Solid work!
