The new DD.
Angus
Bentonville, Arkansas
The new DD. *Now need advice with LIM gasket replacement...
Picked myself up a 96 Olds Cutlass Supreme coupe for winter and mustang down duties.
3100 v6, 4t60e trans
103k miles, clean car, no major dents/dings/scratches
Runs Fine, AC does not work. (I don't care)
Needs intake manifold, rotors and pads.
I paid $200 for it
not bad for 200 bucks i guess. your mustang looks kinda like a jealous stalker in that first pic :rofl:
eckoxl
Geneva, IL
If you need help changing the gaskets, let me know. done it 3 times.
PANDA
FRG
Nice now but another motor in the back.
ilikemtb999
I eat dirt
Denver, CO
theres a kid running around up here in mchenry Co. with an l67 swapped cutlass. from what i recall its fairly fast. Scott is his name i think....
bikrboy128
Some say.....
Wheaton
i will also offer my assistance with the intake gasket......or L67 swap ;)
Angus
Angus
Needs to run like a champ this winter and I don't care about it, really.
$ goes to the stang now. This gets everything that's only necessary and on sale. lol
Angus
Angus
Oh and started the gasket replacement Today:
Leaking coolant like crazy GM 3100 v6
after tearing it apart
one of the problematic coolant passageways
The oil is milky white... uh oh.
ALSO, When I was re-installing the LIM, I found that the new tightening procedures and torque specs for this were in this order:
4 vertical long bolts 62 ft-lbs / 4 angled bolts to heads 62 lbs / then re-tighten the 4 vertical long bolts to 115 lbs / and finally 4 angled side bolts to heads to 115 ft/lbs.
That seems like a lot and I think I even snapped a vertical, long bolt even before reaching 50 ft/lbs... So I called it a night and will re-attack it tomorrow...
I have also heard of these replacement bolts that GM came out with for this LIM... WTF?
Harbor Master
true story son.
no one will seee it comin tho.... :s00ls:
FUCKINracecar shit all up in this mofucka.
Harbor Master
mchenry
mofuckin rain mofuckas.
telll yo mothas
32vMonte
Car is broke
Yea like you have already found out it was in-lbs, also did you use gm metal gaskets?
I got regular plastic ones from the parts store and didn't know about the metal ones from the dealer. I was told to use them and they wont fail again.
Also they say to replace the bolts in the service manual but I just used loc-tite the blue kind. That's what comes on the new bolts.
The only reason they recommend new bolts is for the thread locking part. Trust me I had to redo a job my dads buddy did on my 3100 and noticed there was no loctite on the bolts and they where loose enough that I could take them out with little to no force.
Angus
Angus
yeah, well I have to get the new bolt set now...
Drilled and backed out the part of the bolt suck in the head this afternoon.
And from what I've put together, the new metal gaskets just have a metal spacer in the gasket around the water passageway to keep the manifold from squashing down onto the gasket too much. Well I got that one.
DanJoy
Didn't realize you were so mechanically inclined Angus. 115 ft/lb does seem excessive seeing as the 3800 LIM is only 11 ft/lb and the blower is something like 17 ft/lb.
