Alright, I stopped by for an inspection and this is what we got...
An 02 longblock with a 97 TB, PCM, and wiring (blower is 02), vacuum plumbing does not seem to be correct on the blower for 97. The battery seems to be dead as now the starter does not even turn (all the plugs were out). Half of the used plugs were Champion and the other half were Delco (half copper half Iridium but not a hybrid). Only the UIM (blower gasket) was changed. Water level in radiator (no antifreeze) dropped and at one point the oil was chocolate milk. Main serpentine belt is not completely on the air compressor pulley and could be rubbing on the body of the air compressor.
Game plan:
-charge the battery
-adjust the belt
-crank it over w/o the plugs in and look for water coming out spark plug holes.
-check for spark as we discussed while the engine is cranking
-we may need to tear it apart again to change the LIM gaskets next time i will bring my pressure tester.
-evaluate the need for a replacement starter.
savvy?
also we talked about the possibility of an injector hanging open causing the hydrolock but you may be missing the boat on the coolant being the cause of the hydrolock. is there a better way of killing the fuel pump w/o going through the back seat?
