The downside of beautiful weather......
HellPIG
1,323
1,825
Mount Prospect
Meth is a bandaid. Car is on E85. It is the IAT's post blower. Onboard readings show 125 degrees idling in 85 degree weather, but my datalog shows actually 140. The car will start pulling timing at 140.....
I have a big 3.5" heat exchanger sitting in my garage that I'm finding time to put it....the killer chiller is the ultimate plan, but I'll try to combat it for now. I'm working on trying to isolate my filter a little better too from the engine bay heat to delay the rise from sucking hairdryer temperature heat. The benefit we have here is......March/April and Oct/Nov.....
HellPIG
1,323
1,825
Mount Prospect
Meth is not a bandaid.
Sure it is. I compare it to running a boost a pump on a system that actually needs more fuel.
If your meth "pump" decides to quit. You go lean, and then bad things happen. It has great benefits and cools the intake charge excellent, but my paranoia would always be worrying. There are guys that use it to make big power on pump gas.
Rent Free
24,552
20,568
Nowheresville North Dakota
No thats not how you setup or use meth.....
You use meth as a failsafe to prevent bad shit from happening like pulling timing in this case NOT tune the car on meth and ADD timing.
In that case then yes meth would be a bandaid. Without the drug in this case the meth the engine would not be happy and likely eventually become suicidal.
LOL.
Class dismissed.
RedBeard
4,019
5,469
Windsor, CO
Sounds complicated. I'll hop in and beat the fuck out of car and I don't even have any gauges, not even oil psi :lmao:
I really enjoyed having no gauges in my Cobra. I’m sure if I did I would have just worried more often about fuel pressure and wideband readings. Hell I just figured the pulley combo was supposed to be about 20psi, never took a boost reading :jg:
1quick
26,610
24,225
coal city
At idle it would be high it should drop when driving, if you watch the sensor when you get down on it it should drop a bit at first with the rush of outside air then start rising fast as the blower heats up, the big exchanger should help, I run a 7 gallon ice box the added capacity helps a bit as well
HellPIG
1,323
1,825
Mount Prospect
Yea it drops always, but not enough for my liking.
Once that blower gets warm it's hard to go back. The Killer Chiller uses the cars A/C to cool the coolant. Seems like the ultimate way to go to not lose timing between hits in warm weather. Guys have seen IC coolant temps down in the 30's-40's, which drastically improves the air charge post blower. It's liking driving around with a frozen blower.
cdh027
8,779
14,292
Sunny Florida
LOL.
Class dismissed.
So the way you describe using it, you would be ultra rich under WOT, but cooler intake charge? I'm guessing you wouldn't gain a lot of power, just safety?
01Cobra
Johnny Cobra
May 3, 2006
8,686
3,207
It’s worth it. Especially now with the TVS. I’m going to order the remote bypass for even more cooling. The heat exchanger becomes a heating element to the killer chiller once it gets beyond 90f.
95SC
4 cams
3,524
6,773
TN
Yea that's the issue I had with my previous cars that had PD blowers ,on the other hand I don't have this issue any more now LOL .If it was 80*+ outside it felt like car was making 100hp less. Last year at 1/4 mile track my buddies CTS-V was hitting 150-160* , 96* was the highest my car saw that day . . I logged couple passes last year at 1/2 mile event , IAT never got above 100* during a 1/2 mile pull [up to around 165mph] . It was hot and humid 80-85* outside that day too
Here is my 1/2 mile log
Pressure Ratio
20,514
12,422
Glen Ellyn
Most tuners will set it up so that if the AIT rises past a set temp the ecu will add fuel and pull timing. Sort of a fail safe. It isn't the best option but beats losing a pump and the ECU doing nothing.
LOL.
Class dismissed.
What are you talking about? That isn't how the rest of the world uses meth kits.
The Killer Chiller works great. But like Johnny said, it can be set up better. I would say that it is a great option for a street driven car.
Water / meth injection works great when sprayed after the air is compressed. When used on a positive displacement blower and sprayed before the blower, the cooling effects are reduced. Due to the compression of the air increasing the heat of that air again. But if the air going into the blower is cooler than ambient air, it still helps.
Also, the cooling effect comes mostly from the water. If you are worried about a tune being more aggressive with the water/meth mixture, and losing the pump, just run water. You can also have it tuned to run on just water and then run a small percentage of meth with it for track days and what not. A little added insurance with the added octane. The a/f will richen a little but if the mixture isn't extreme it would still run fine and not cause issues.
Water / meth injection can be a band-aid if you are using it just to increase your lacking fuel system capacity. But it is also an option to add levels of efficiency and power potential.
