your still salty that you can't hack it.......dont worry...we'll sho you how
I believe we have the solution but no time to do it. My valve body changes will help a lot. Ultimately there might still be weakness involved. Torque management slow boost ramp on, is what i should have worked on. With a quicker 1 to 2 shift i could have used 1st gear at low power vs using 2nd gear start with a shitload of torque.I figure'd Ben put in more actual time and real world work to find out
you can't make power on an 80e for long with the # of them he ruined.
So the fix is.. make weak power and good to go
Also just going to a good track this car wouod have easily made a 7s pass at medium boost not hurting anything.
I realized how bad our local track was this summer running our 600hp asphalt sled. Anything over 20 psi was a smoke. Show.. We ran 5.21 @142mph at 22 psi snaking down the track.
We then went to a decent track 5.0 @149mph right away snaking down the track. And tue racers from Michigan told us the track was slippery lol.... Milan same guys that ran 5.0s @149 too ran 4.6s. up there @156mph
Wanna buy the car?Hopefully you get back to it one day...
Once the 80e thing "figured out" , love to see it applied in a single engine FWD setup making big numbers and see how long it
lasts hauling 3000lbs+ alone.
Wanna buy the car?
I have the. Fiberglass. Body for it too?
Ill Sell you everything i have for it...
Fwd less. Traction would br rrally hard to break ona gutted lightweight 3.8...Hopefully you get back to it one day...
You'd be the best buyer for it too you are patient...Figures you'd do this after the fact that I bought the old Whipple car.
Wanna buy the car?
Just the cage or you want as much hardware as possible?How much. Less body
