MarauderBC4E
Active member
More questions. P1SC has a 3.75" inlet and 3" outlet. I assume I would need to use a 4" inlet tube and use a reduction spacer to get it on the head unit. Can all of the output tubing be 3" right up to the throtle body?
I have a tig welder, mig welder and access to a full machine shop. I really want to do it myself. Plus I'm cheap! Got one daughter going to college and another two years behind her! It's going to be a couple of years of gathering parts on the sly.IIRC the TB inlet is 4-1/4"~4-1/2" You can get a silicone reducing 90* that's 3" to TB.
www.frozenboost.com
Doesn't Landy have a guy that makes A2A pipes? Shoot him a PM
I looked at that pipe kit and blow through maf! Thanks for the confirmation that they aren't crap. I'll look at the intercooler too, Thanks!You use 3" piping.
I used this:
Cxracing 3" 9pcs Free U Pipe Intercooler Piping Kit | eBay
Dont let the price fool you, its an awesome kit for the money. It comes in black too.
You want this intercooler, fits perfectly:
TR1035 Intercooler 666HP- TREADSTONE PERFORMANCE
Set your kit up for a Blow-Thru MAF.
I recommend buying the MAF from here:
PAS Xtreme Mass Air Sensor
Its a re-badged Pro-M for $60 dollars less. Then buy the appropriate wiring harness and flange.
6 Pin 6 Wire Pigtail - Mass Air Accessories - Mass Air Meters
Drop-In Sensor Weld-On Flange - Mass Air Accessories - Mass Air Meters
thats a good deal on that 3" pipe kit, thanks for pointing that out i just picked one upYou use 3" piping.
I used this:
The air would get cooled in the A/A intercooler, then get heated up 50+ degrees in the Procharger style hat.Hey Zack I have a centri question for you. I have yet to see anyone use both cooling methods on a centri. Would it be feasible to go A2A and use a 03 cobra lower with a procharger W2A upper hat? I would think it could be the best of both worlds
Just wondering
3" but you can get about any size from them, it looks like as good if not better quality than the treadstone kits I've used and it was over 100 dollars cheaperLooks decent, what size pipe is it?
