a nice tool to make sure the vpn is working is to visit ipleak.net while connected/disconnected
Well my work VPN passes the test, lol :rollpicard:
Totally forgot my pihole's log in information so I can't update or do anything. Time to wipe and rebuild.
Nah, changed it because I'm not an idiot. :wink:
Except now I've forgotten it because I touched it once and never touched it again.
MicroCenter is literally across the street.... So far, yet so close...
TICK TOCK COMEON 10 OCLOCK!
Sooo I wanna do this, but I read through this thread and now I’m somewhat confused. I’d like to have both the ad blocker and VPN, is this doable with Xfinity WiFi? I use to be a little computer savvy, seems I’ve lost that! Some of it seems easy but I’m afraid I’ll buy it try it and then give up.
What will your VPN be used for? Self hosted or third party?
Both serve different purposes. My home VPN allows me to be on my local network while not at home, consider it as a secure extension of your network to outside the house allowing you to access your computers and devices at home while being away.
I use my home vpn to be able to see my home automation stuff when not at home without having to expose it to the internet. This will not work for torrents since your IP address will still be on the VPN.
A third party VPN (I use PIA) will allow you to change regions for different services, mask your original IP and wrap your data in a secure connection that should be free from prying eyes (and ISPs). I use this for torrents and to change regions.
ive done that enough to where i use a password manager immediately when i change it... otherwise itll be forgotten forever
By then she'll be out and I'll need to be here.
Surely she can wait in the car while I run in after her surgery? Right?
From the quick reading I have done, I dont think the Xfinity setup will let you change the DNS server. That doesnt mean it will not work, but it requires more network jargon that makes my head swell. Like having pihole be your DHCP server and then manually setting all of your devices IP addresses manually and OMG............
So, I can have a VPN running on my own network, and use that to log into my machines and not have it be a third party like Nord or TunnelBear? Cause if so I can use OpenVPN on unRAID.
Walk in, all the way to the back, turn left, all the way down. Usually in a bin. Get a 0 and a 0W even if you need it or not.
Then you want a third party like PIA vpnUhh.. I’m renting right now so not a thing as far as home automation or accessing any cameras or the like. Mainly just to keep xfinitys nose out of my business. Even then I probably am not even a blip on their radar since I hardly ever stream something I’m not paying for.
Step it up one notch and block 10x domains by adding this list instead:
Yeah that list is pretty good at allowing alot of stuff that most people useI have been adding but hadn't made a bit bump.
Thanks I'll do it when I get home
I'll have to give this a shot as well. See if it passes the GF test.Yeah that list is pretty good at allowing alot of stuff that most people use
So far this has been the best one yet. Haven't heard a peep from the wife after just redoing the pihole. Usually i hear somethingI'll have to give this a shot as well. See if it passes the GF test.
I think I was most worried about tiktok. So I was looking at the admin page and she was asking me questions about pihole so I took that opportunity to load up that block list and had her tiktok. So far so good.So far this has been the best one yet. Haven't heard a peep from the wife after just redoing the pihole. Usually i hear something
