Right now just ipv4. Turned off ipv6 router and device side if possible, no use or advantage for me. Used this guide for dns over https:How did you do that? Do you do IPv6 as well or just v4?
https://docs.pi-hole.net/guides/dns-over-https/
Pfsense or ubiquiti or mirotek router is my next project.I run pfBlocker on my pfSense box and love it. Aside from the occasional certificate error when visiting websites for the first time, it works great.
can someone dumb this down for me?
i no understand
My buddy set up a watchguard with about $160 in equipment and keeps telling me I have to as well. Probably eventually but right now I am in a space constraint.
I want to do this just for the geek factor.
That's pretty much why I did it. I still run ad blockers on the computers, but it's still blocking about 18% of my DNS traffic. It blocks the random stuff from Alexa, the TV, etc.
teamviewer....
Here is a little tip for Pihole....
if you SSH into it and add your device IP address and a name to the Hosts file (located in /etc/)
your devices on pihole will show up with names you give them. Granted this also requires you to set static IPs on the devices or setup DHCP reservation on the router so they don't change IPs.
but you get much better stats on which unit is causing the most traffic:
21% of my internet traffic is junk ads....and that is blocking less then stock since I allowed some stuff i usually wouldnt for the wife
midnight rambler over here
Also, those are some rookie numbers guys. Gotta get those blocked domains up. Then again, that might be part of my problem.
can easily be done for less then 20$
pi zero W - 5$
8/16/32gb micro sd - 5$
power supply - 5$
case (not required) - 5$
Need a 0 or 0W? I might have bought too many.
no wonder why you are having so many issues
also your graph is so smooth
nope i have a few laying around myself
every time I am in Microcenter I buy one of the 5$ ones even if I don't need it
also use your pihole and install pivpn on it too. dual purpose and no more teamviewer needed!
pi zero W - 5$
power supply - 5$
Right? I still have some testing to do. If anything, Ill go back to the stock lists and maybe add a couple more and see how it goes.
Also gotta remember no one is technically home yet. This is just devices idling. Apple TVs, Echo Dot, game pc, server pc, PS3, PS4. Kinda scary that these devices are trying to get info out.
How hard is this to setup for those not familiar with raspberry pi
eh they need to check in for updates. I block stuff that doesn't need internet.
Like my wifi plugs try to call home so you can control them remotely...never setup an account so....blocked
ip cameras...blocked...no need for internet.
everything else i check up on occasionally and make sure a device isnt making crazy amounts of requests. That is when you know something funky is going on and the device may be compromised.
