Need help please.
03sport007
Aug 4, 2011
9
Quote:
Originally Posted by Blown3.8
I use a small screwdriver between on the corner where a bolt is so I don't make a ding on a critical sealing surface. To get a little gap as previously mentioned. Then take a razor blade and run it in the gap to cut the rtv. Once you get a few inches form the corner going on both sides then lifting the blower will keep tearing the rtv.
Just make sure you flaten the spot where you put the screwdriver before it goes back together or it might not seal the next time around.
I also like using loctite flange sealant. Its not sticky like RTV so it comes apart later. But you have to have thick flanges like on an eaton. It doesn't work so well on the trilogy plate cause its thin.
That was the ticket. Did a little grinding to a screw driver to make it thinner and got aggressive on a non sealing area. Worked a couple areas and it finally popped!!!! Thanks
__________________
03 SB 300B
Eaton Swap Tuned by Fast Specialities
Trans rebuilt by Darin at BC Automotive with a Triple Disc 11in Circle D TC. Tuned by Zack. The man that made my Marauder fun again.
4.10 gears with Cobra clutches. No more one wheel peel
Metco Drive Shaft Loop.
Next bigger brakes!!!!
  • 0
  • 10
  • 590
