Sweet!
Who did the welding, Bill?
I finally have the fuel problem sorted out and the car is running quite well.. Only one big problem, the torque converter.
I bought a FTI Triple disk with a 3200 stall. I swear the stock torque converter is in the car. It is way too tight and does not flash even close to 3200. So, Im taking that converter out, having it restalled and will install it in my Whipple car.
In the mean time, I just bought a Circle D Triple Disk 4C with a 4K flash.
Circle D converters use a different stator than FTI which makes them considerably looser. My heavy turbo car definitely needs to build rpm's fast or its a pig.
Will install when it comes in.
Hmm, you should look ask about switch pitch converters for your application...problem with super high stall and a turbo is not enough drag to spool and then it falls on its face. The Buick guys have this issue figured out...
Did you get any 1/4 mile times for that beast yet??
It will be interesting to see how that stall works out for you, ive never been a big fan of high stall converters in street cars. I had a 3200 stall in my Turbo Buick and it felt like instant boost off idle.
Whats not to like about that?
The boost? nothing raising the engine to 4k to get the car to move? just not my thing
You must be buying cheap converters.
