🔧 Technical LSA Blower or Turbo?
Pro Stock John
LS is the best engine
10,631
14,537
Chicago North Side
317s + 6.0 might be kind of mild on compression, 9.4:1 or something? If you are stock rotating assembly I would not do fancy heads because if the stock rotator breaks the heads might get damaged too.
I'm still thinking LSA, ZR1 blower, something like that, pin the crank, pulley it to make some power. Are you stock computer? What fuel do you plan to run?
Custom turbo systems are not that easy. I think if I had come across a COPO supercharger in the past I would have gone that route.
107,635
Holley Terminator for computer, more than likely will run flex if its possible, if not I'll run straight corn.
Reactions: sktchy
Pressure Ratio
20,514
12,424
Glen Ellyn
With decent overseas made turbo exhaust manifolds/headers, the compact size of the LS motor, the large engine bay, and such lend me to believe a customer turbo kit wouldn't be that bad. You can get reliable turbos for cheap and knock-off intercoolers that are inexpensive and work well. The one thing Jon01 touched on it heat management. Investing in ceramic coatings, DEI wrap, and heat shields can make a huge difference in the heat underhood. As well as the efficiency of the turbo system by keeping that energy (heat) in the tubing & turbine housing. On my Capri, I had the tubing coated and wrapped it in DEI heat wrap. I could touch the downpipe off the turbo after it was running for 5 minutes. Ya, it was hot to the touch, but you couldn't do that with bare exhaust tubing after a set of headers.
I know you are aware of how heat soak can affect the performance of the LSA. I think managing heat in a turbo setup is typically easier and cheaper than say a Killer Chiller or large water tank setup on an LSA setup. Although that water tank filled with ice is going to work much better than the air to air intercooler on a simple turbo setup.
Planning stages of either setup can save you a lof time, money, and aggravation. I'm excited to see how it turns out with either combo. It will be one sick ride when done.
Pressure Ratio
20,514
12,424
Glen Ellyn
Ya, just be honest with the power you want and the expectations of the build. There is no "one size fits all" turbo. Many of those cheap turbos seem to have overly large or small turbine sides. But you can easily get a $1200(ish) turbo with specs that will work in the design window you want. I love the Borg-Warner turbos. They have some great options and reasonable pricing for custom specs. But you have lots of options out there for turbos. Heck, even some of the overseas turbos have worked well in budget builds and seem to last. Who knew?! haha
Pro Stock John
10,631
14,537
Chicago North Side
True, lots of inexpensive turbos out there. True an LSA will heat soak, though a few Caddy 'V friends ran stuff like the interchiller, which I assume is some sort of improved a/w kit.
If I were you I'd for sure da flex fuel sensor. Yesterday my pump of choice was out of E85 eek, but I went to the one I had heard about another mile and a half away and they had some. I'll prob plumb in the flex sensor over the winter.
LikeABauce302
5,928
16,523
South suburbs
Matt
A tried and true Borg Warner S480 would work well on that setup. There are a lot of options for turbo manifolds too. The Hooker cast iron turbo manifolds are really nice. With a nice turbo setup, you won't have to worry about belt slip issues. I've had multiple friends struggle with shredding belts when they pulley down a blower setup to make big power.
Reactions: sktchy
