• 💡 Fun fact. Whenever you start a thread, TCG Mechanic 5000 (our AI bot) will reply to you to start helping. It doesn't know everything and it will struggle with more complex questions but it can get the thread going and provide valuable information. You can choose to disable it prior to submitting a thread.
LS 6.0 starting but doesnt stay running
107,609
From 60 to zero was just cycling the key on. Had to wait for someone to get home before I could test it running. Sorry about that. I’m gonna try that tomorrow, i usually use brake cleaner when testing for leaks.
Yes it ran perfect last time I drove it. So I’m like WTF as well. I’m really good at fixing shit, but horrible at diagnosis work.
Reactions: Jon01
107,609
That's how I read it. It should hold steady for 20 - 30 minutes. Sounds like it's bleeding off somewhere.
Kinda what I thought, but the guy that did my build said its normal with my set up.
I'm running the Holley gas tank with Holley 225 pump iirc. Going that route was pretty much plug and play, also all fuel lines are brand new.
Dont smell fuel anywhere and chased all the fuel lines back, they are all dry
107,609
Okay so after dicking around with this off and on and getting absolutely nowhere. Towed it to the guy who did the build in St Charles.
He pulled plugs and they looked fine, just a little wet ( I already pulled them and told him that). Pulled the o2 sensor and was completely fucked. Ordered a new one $140 thru it in and car is fine....smfh. Told him why didnt he suggest that to me, and he said it never crossed his mind until the car was there. So talking with Satera he was leaning towards an exhaust leak, but if so we both would have thought the plugs woulda been fouled out as well and they arent. Scott (guy who did my build) was at a loss as well. Only thing he could think of was when Valasquez welded my exhaust to the headers. The o2 sensor sits right there and maybe they fucked it up with all the heat and over time it got worse. I 100% checked for exhaust and vacuum leaks when fucking around with it. I need to get a smoke machine on it to be 100% sure.
So what do some of you guys think? What could have fouled out the o2 that bad to there the car wouldnt stay running?
This o2 comes with the Holley terminator system.
107,609
Got any pics Shawn?
I suppose that the heat could have killed the o2 but itd have to get pretty damn hot.
I think it's more likely the o2 was just defective and didnt die right away.
Glad you got it fixed!
I'll get a pic from him, I saw it and has to be the worst o2 I ever seen lol
I got this fucker sold and it keeps acting up, now I gotta get it back to my painter for bumper fillers to be repainted.
Ive gotten most of the money from my buddy, I might just tell him take the car and hold what he owes me till the spring time. Then go get paint fixed
Reactions: Jon01
107,609
Do you have an idle adjustment screw on your throttle body? Try adjusting it to open the throttle blade more at idle. 40% IAC is a lot. At idle, it should be around 5-10%. Once you adjust the idle screw, you have to do a TPS reset.
Tried that while I was troubleshooting it and didnt work.
Reactions: LikeABauce302
