JLT high boost CAI install problems...
grey03svt
Active member
How does this filter fit into the fender?? does it go straight down, or up and over the fender???
the filter is getting trashed trying to fit it in there......
01SVT19
If I remember correctly try taking the fender liner off and installing it from the bottom to avoid any damage. I believe it sits vertical and goes straight down.
grey03svt
grey03svt
Active member
ya i got it there now. i had to roll the inner fender edges got get it to sit right, i still think the thing is way to big to fit in there. it is touching the plastic fender well, and im sure vibration is going to hit or rub on some sharp in there....
TwoTonedRoush
Active member
Your right it will rub. I have one on my cobra and a while back when I took the bumper off for the new paint job I noticed a hole in the airfilter. Also when I installed the kit I had to cut the rubber peice that connects to the throttle body just to get it to fit. These kits kinda suck.
Dana
Bluesmobile
Cut the bottom of the fender liner. It will fit better. You can trim the edge of the fender liner with door edge guard.
Mth180
I did what Dana said except I removed a large portion of the plastic in the wheel well. My Cobra only goes out on sunny days so I don't need to worry about the filter getting clogged with dirt and water. I actually have a 12 inch filter on the end now instead of the 4x6.
Dana
Bluesmobile
I have the 12 inch filter too, maybe I should have mentioned that, but I actually thought that was the only one that came with the fenderwell version.
Anyway, the fact that my car isn't out during inclement weather was the reason I didn't mind cutting the fender liner. The door edging prevents the sharp liner from cutting the filter element plus dresses up the raw edge.
Fordman
mine stutters during heavy rains so i have to take it easy going through the gears or itll buck, scares the crap out of me too when it does. I did however plug up the air inlet next to the fog light on the front. on my way home from the 45th in Alabama when it was pouring and didn't have any problems.
TCG Member 5219
The fitment of those things is shit. I had issues with my on my 04. Great gains though!
Zack
4 Doors 4 Life
NW Indiana
Anyone using this CAI should use a pre-filter to keep the water out.
