It’s 2021, I need a new floor jack
Bob Kazamakis
I’m the f-ing lizard king
85,583
45,895
Joel
So what say you guys? Looks like they’re hard to come by these days and things have gotten more expensive
My craftsman aluminum jack is no more and had a 15 year run.
I’d like something that goes to 19+ inches for height and low profile would be a big benefit if it was low profile since I’ve got two low vehicles as well as two tall ones.
Bob Kazamakis
85,583
45,895
Joel
I went today and they literally had nothing but the small 1.5t aluminum in stock
This one caught my eye but I’d probably have to wait till shit is in stock
Reactions: Rdrnnr
SMRTSS1
5,166
7,636
I’ve had the Pittsburgh (Harbor Freight) 3 ton aluminum for years and I love it. Low enough to get under a regular car, lifts high enough to get my Escalade in the air for rear suspension work, light enough to move around with ease. Made by the same factory that makes Delco and a few other branded jacks you get at other stores.
Reactions: Rdrnnr
01bluesnake
D Mark Performance
3,406
7,557
I've been using harbor fright jacks for years, but non of the newer ones. Mine tend to go bad rather quickly, but they are to use every day. My current jack needs to be replaced, starting to leak out of one of the piston seals, but has about 2 years on it.
Gav'sPurpleZ
39,126
14,980
Pingree Grove IL
I have an older steel pittsburgh jack from The freight in the harbor. it's a 2.5 ton which they do not offer any more, it's the low profile one that they offered at the time.
It's been fine for 9 or so years.
It works for the rear end o the AT4 but not the front, so I splurged and bought a pro eagle BEAST off road jack :bigthumb:
Bob Kazamakis
85,583
45,895
Joel
Really? My 1.5ton lifted the front of my cucv (both wheels off the ground) pretty easily.
Reactions: Rdrnnr
greasy
36,959
29,100
Oh man that’s low…..and tall :wackit:
It works great, gets under the Hellcat to lift it without me having to drive onto wood. Really makes life easier in the garage. My only knock I guess it the 2 ton rating, but I am not sure it matters much. Very happy with its performance thus far. Used it for my entire rear suspension install recently and it worked flawlessly.
Reactions: Bob Kazamakis
Rdrnnr
wannabe racecar builder
Nov 15, 2020
1,361
2,386
Harbor freight 1.5 is awesome for little stuff.
Big jacks napa/Carlyle 3.5s period. Havin a tire shop I beat the living piss out of them even lifting unloaded semis one corner at a time and they just don't quit, maybe need a lil oil after couple years but that's it, wait til they're on sale tho they're like half normal price
01bluesnake
D Mark Performance
3,406
7,557
That's actually the exact jack I have thats leaking, mine is just harbor freight. They don't have rebuild kits which sucks. Other then that, the jack is awesome, ive just keep topping it off. Its lower then my aluminum 1.5 ton jack, and will raise a car high enough I can get 6 ton jack stands under without maxing.
Rdrnnr
Nov 15, 2020
1,361
2,386
Dude how is that pro eagle I always wanted to try one when I had a service truck
Thirdgen89GTA
19,401
16,024
Rockford
Bill
I've had the super low profile extended reach HF jack, and I currently have the 3 ton aluminum HF jack. Lost the uber low profile HF jack to a friend who is no longer a friend. We were halves on it, so it wasn't worth asking for it.
I got the aluminum because it was 'lighter'. LoL. Its heavy enough that I don't want to move it at all.
I would have been better off with the small 1.5 ton Aluminum jack, and buying the 2.5ton long reach low profile again. A small jack for quick jobs, and a big jack for big jobs.
Bob Kazamakis
85,583
45,895
Joel
The 1.5 ton aluminum hf jack seems quite useless with a 14” lift height.
EmersonHart13
54,261
22,478
I picked this up to replace my Costco Arcan jack and love it. Quality piece.
I have the jack I believe Gav is describing and it is awesome. The one Greasy posted seems to be nearly identical to the specs and it looks the same minus colors. (y)(y) And yeah on the 6 ton comment. That was a huge reason I bought it.
Bob Kazamakis
85,583
45,895
Joel
Alright it’s between these two I think, decent weight difference for about a 4” max height difference and about $50
  • Lift height of 3-1/4 in. to 24-1/4 in., ideal for low-profile vehicles to trucks and SUVs
  • Lift capacity of up to 6000 lb.
  • 103 lb.
or this one (which looks comparable to the okd
  • Lift height of 3-1/4 in. to 20 in., ideal for low-profile vehicles to trucks and SUVs
  • Product Weight 79 lb.
