Interesting, does the inhg go closer to 29" when you close the throttle more. If that reading is accurate it seems like you're near the stalling point.
wait the datlogger shows 29" but the PIDs show 9"? wtf?
Yes, I'm not quite sure where the vacuum reading in the upper left comes from.
I think it might be a reading from when the car is off?
I don't know, I'd have to take a look see with the key in Run and the engine off.
wow low manifold vac even at that rpm ...steady?
.71v seems like too much from my memory
if you think its the air bleed hole, stick a feeler gauge at thelip of the blade to hold it open more and restart. thing is none of yer logs show it maxing the IAC steps to 255 like it wasnt getting enough idle air.
yeah make sure you toss a vac gauge on it, and delete the brake booster hose to make sure its not a vac leak source (old cracked/leaky diaphragms dont always make a hiss audible in the cabin)
plug the vac gauge into as many different vac port locations as possible, the one point that has a drastically varying pulsation of the gauge needle may be near the vac leak. you may have to get it near the stalling point.
make sure you get back to us with the exhaust smells as its dieing out or at the held throttle "idle"
i have to believe that the engine is lean from a vac leak looking at the consistently lean NB o2 voltage
