ive been studying the laser code for the duet RRF 3.2.2 g/m code 3d printer boards that i REALLLLY wwant a fiber laser for a head to be able to swap on
how much power/cross section will it do?
fuck that cant be cheap.
greasy bro.... check this out!
Forgive the video, it just started running. Still getting it all set up
How big of sticks does that machine take?
I am all good Shane, thanks though!!!
greasy done anything cool with the welder lately?
Dude I wish, part of it is me being lazy, part of it is it makes a HUGE FUCKING MESS in the garage, and part is me being crazy ass busy with work. I would rather spend my free time doing other shit.
I still need to design/make a rear brace for WhiteKnuckleScat. Need someone who can cut out plates to my specs. Also need to design/fabricate a front strut brace which will need the plates.
How about you? I think I read somewhere here you are picking up a TIG machine.
I get ya man, especially with it being summer, hot as balls and lots of other shit going on.
The mess does get old too, metal shavings everywhere gets really old.
Yeah I picked up a Synchrowave 210 over the weekend. I had outgrown my Maxstar 140 scratch start machine.
I'm going to build a welding table, then once that's done I'm going to build new exhaust for my C10 out of 304 SS.
send cut send
Online Laser Cutting and Waterjet Cutting Service
SendCutSend is an online CNC and laser cutting service, specializing in aluminum, steel, brass, plastics, titanium, and more. Fast turnaround and free shipping!sendcutsend.com
They do a lot of cool stuff. Or I should say make parts for people who do cool stuff. Pretty affordable too. I ran across them on the gram.Dude this is awesome, thanks!!!!
Why do you think that?Waterjet > laser
Waterjet edge quality depends on the operator and the quality they select. I believe it's between 1 and 5 plus of course there are speeds and pressure that matter. They can leave a very very abrasive edge and likely need to be cleaned before welded (regardless of the process, laser, water jet, plasma etc)Waterjet cuts are a little easier to weld. From my experience, laser cut edges can need some extra cleaning and prep work. There may be some oxidation and scale or slag from the laser process. Nothing a flapper disc on an angle grinder can't fix. If the edges are going to be milled, shaped, or you're tapping laser cut holes, the edges will be hardened slightly. Nothing more than a slight inconvenience, but it's annoying if you're used to working with waterjet cut material.
