GI 2000 GTP that runs low 12's
Ron Vogel
Bolingbrook
Thinking of selling my car to move on to something a little more normal.
Before anyone freaks....remember, I have been using this as my DD for 8 years. There's nothing major wrong with it other than age and milage. I'm just sick of it, and want to do something different.
I may sell it "as-is"
It needs new front hubs and 1 axle, but drives OK. The front struts could use a changing, but overall the suspension is good. The axle works fine, but the boot is torn (May just want to replace the boot, but I will normally just replace the whole axle). The Hubs don't hum yet, but my ABS light will intermittantly come on (that coupled with the milage since I last replaced them leads me to think they should be swapped out)
The engine runs like a champ, but it does have some quirks. The front cover is leaking, and needs new gaskets. The motor never had a leak until I put the new timing chain on 2 months ago, and I suspect it's the seal at the harmonic balencer. I also replaced the power steering pump when I put in the new TC and tensioner.
Car has no emmissions equipment. No PCV (well externally sumped anyway) no Cat, no EVAP, no EGR, but has passed IL inspections w/o an issue. I have all the pieces other than the cat to put it back to stock.
Car has been hacked up in a few places (tirewell flipped for muffler clearance, some custom brackets, yada yada) all can be converted back, if you need to.
I have a whole extra brake system, the bumper supports (not on the car)...a bunch of extra stuff. Even an extra L36 block if you want...
145K miles!!! and trust me the body ain't perfect (hard sell huh?)
You can buy the whole deal for $4500, part it out yourself. Car is fast as ***, or just hustle with it. Car is trapping 115 right now on the stock bottom end and cam...idles like stock. (and gets 30 MPG hwy)
I'm pondering parting out the mods for it then selling the car whole, or just parting everything on it. The car is capable of 11.70's as it sits if you can get the launch right. Car has been a trooper over the years and have had no major issues. The block, heads, trans are all original and have never been out of the car or serviced. The deepest the motor has been into is replacing the LIM gaskets with aluminum ones.
I have some vids on myspace and facebook, as well as other that are on youtube from other people. Car Dynoed 293 to the tire on a Mustang dyno with full exhaust. With the dynojet correction puts it at 328 to the tire (#1 HP record m90/stock cam), unplug the exhaust and throw it on the dynojet and it will probably pull about 340hp.
MODS ;will be hard to remember everything, but:
HAI with big K&N
Custom LS1 TB set-up with adapter and body blended into SC. LS1 TB is epoxied and smoothed internally and has the thinner L32 throttle blade. Has been modified so that the PCV functions normally.
Ported SC inlet/outlet. This was a custom job by me, it's perfect. The blower just got new bearings and rotors 6 months ago.
WBS IC, this was a pre-production unit. I modified it to have the PCV work like stock. I also opened up the inlet and outlet to match the blower/lim. The core in the basket is a ZZP one. The original was trashed, so I got the new core about a year back. The IC system has a 10GPM pump, and I have a Griffin 2 row racing radiator as my FMHE. It measures something like 31 x 12.5" ...it's something like $300 or something from what I recall.
I have a custom extra idler system along with a custom pulley set-up for the SC belt.
Motor mounts are all custom fabbed.
Modded S&S headers, 2.5" stainless exhaust to f-body muffler
LIM is port matched and polished.
Accel wires
relocated the coils because of the custom engine mounts.
Custom fuel rails
57# injectors
MSD BAP
Walbro pump
smaller brake booster
custom lower control arms
grand am brakes
modified trailing arm mounts
AC delete
Bigger engine radiator / bigger internal trans cooler
Shift kit
external PCV with monitoring guage and oil seperator
1.91 modified stock rockers
AFPR
2.6/2.7/2.8 MPS
GMPP lowering springs / KYB struts
Any rust Ron?
The leading edge of the hood is starting to get it pretty bad. Right under the gas door there is a small bubble that hasn't flaked off yet...that's about it for what's visible. On the pass side strut tower to firewall there is a pretty good spot that I routinely paint over, as well as a spot in the trunk on the driver's side strut tower.
Car is pretty clean overall, but it is 8 years old so there are some dings and imperfections. The worse one is by the pass side headlight. I backed into the car with my wife's old Pacifica. I replaced the light and corner, the bumper popped right back but the paint is spiderwebbed up pretty well there, and the fender popped back out, but needs a little more TLC to be right on.
Overall, it's not bad for it's age and how little effort I put in to appearance over the years. Somebody handy with all things body related could get this thing to be a looker without trying too hard. I used to to auto body so I have a pretty good grasp of the condition. If I were redoing the car I would definately replace the hood and front bumper skin, everything else would be easy for prep.
Pics of some of the custom parts here:http://www.clubgp.com/newforum/tm.asp?m=4462619&appid=&p=&mpage=1&key=welded&language=single&tmode=&smode=&s=#4463219
PANDA
FRG
Im locking this thread, you cant sell your car~!
EmersonHart13
John
This car should be made into a race car and immortalized forever.
Ron Vogel
Ron Vogel
Bolingbrook
Before anyone gets shocked that I'd sell it...remember this : I've been driving this thing for 8 years....that's an awfully long time to own a car.
The longest I owned anything prior was 5 years.
Harbor Master
Ron... put this on CGP, there are enough people in your fan club that would gobble this shit up IMO.
El Presidente
dont sell it until after the track day. i want to see it run 11s once. if i have to pay your entire way down i will
Harbor Master
Ill put dollars towards the rons 11s fund.
Fish
From the mean streets....
Chiraq
I look under that hood and see $$$. Too bad I dont have the $$$ to see the further $$$. :(
Fish
Chiraq
Ill also X2 that. You could probably even tach on an extra $1500.
Ron Vogel
Ron Vogel
Bolingbrook
Yeah, I want to take it there too, but I don't want to risk it. It would put me in an awfully bad spot if I killed something major.
I'm not trying to screw anyone, so I only put it at $4500 on CGP.
ilikemtb999
I eat dirt
Denver, CO
ah ok. i thought i remember reading you were building up a new short block.
ktraver97ss
I say what everyone thinks
Roselle, IL
hmmmm...my nephew is looking for a ride....this may be too much for him to handle though. He'd prolly wrap it around a tree or something. I should buy it and ditch the TSX. No payments and lower insurance would be sweet. Then again, the wife would prolly crash it too, so nevermind.
Ron Vogel
Ron Vogel
Bolingbrook
I was going to, just can't afford to.
I thought Mike K was going to help me afford the rebuild, but it didn't happen. He did get me the block, but it's got 70K on it, and I dissassembled it for good measure. It's in decent shape, but needs new bearings. For a car intending to be a test mule/advertising whore everything should get done right. I wanted to have the block squared up and rehoned at a minimum. The work between the block and the heads would have run about a grand, and in my best estimate were worth around 40-50 HP.
I'm not-super happy about it, as my car still doesn't have the new block in it, it takes up space in the garage, and my car is still on WBS's site as well as advertising banners. I get absolutely nothing out of it.
Fish
Chiraq
Wow.
EmersonHart13
John
Fish, I am surprised with your restraint. I fully expected you to type more than 3 letters. lol
