NEW RIDE FNG Part II
Bonj87
Bonj87
Posts
138
got her on the streets today. i need a shop to do ball joints on her.. and then i gotta get tires and have the brakes cleaned\checked.
Thirdgen89GTA
Posts
14,058
Buffalo Grove
Might want to consider replacing the steering Rag joint while you are at it. It'll clean up any slop that exists between the steering wheel and input shaft on the steering gear. They get old/weak and flex a ton causing quite a bit of transition slop. Contributes the stereotype that they wander all over the road.
If the rag joint already has bolts/nuts its been replaced. if its got rivets then its original.
Bonj87
Bonj87
Posts
138
im new to third gens.. ill be honest.. dunno even where to look, but based on everything else, im betting this things is 100 percent all original
Bonj87
Bonj87
Posts
138
replaced all the clips\plastic screws in the hatch, so now all the covers fit like factory.
Bonj87
Bonj87
Posts
138
Order entire front end today. I have clunking while driving. It's gotta be them. So much play in them
i dont have the ability to redo the whole front end at home myself, which sucks
