im new to third gens.. ill be honest.. dunno even where to look, but based on everything else, im betting this things is 100 percent all originalMight want to consider replacing the steering Rag joint while you are at it. It'll clean up any slop that exists between the steering wheel and input shaft on the steering gear. They get old/weak and flex a ton causing quite a bit of transition slop. Contributes the stereotype that they wander all over the road.
If the rag joint already has bolts/nuts its been replaced. if its got rivets then its original.
i need to get the ball joints replaced, badly
i dont have the ability to redo the whole front end at home myself, which sucksOrder entire front end today. I have clunking while driving. It's gotta be them. So much play in them
Upper strut mounts? Just tossing it out there.Also, while driving, do you notice the ball joints are an issue? How do you know they're bad?
I have a solid clunking by my feet while cruising. Lifted her up and everything is super solid besides the joints... Nooooo way that's the joints..
when braking, she pulls.. plus we had the vehicle up on stands and wiggled the tires while looking at the ball joints.. there's too much play in them.Also, while driving, do you notice the ball joints are an issue? How do you know they're bad?
Does it consistently pull to the same side?when braking, she pulls.. plus we had the vehicle up on stands and wiggled the tires while looking at the ball joints.. there's too much play in them.
If no rain are you planning on attending 3rd gen expo tomorrow?worked on a few things.. got the water pump done, tune up.. brakes worked out.. put 20 miles on the ole girl and she drove like a dream!!!!!!! then stopped for some pics. BLOO and DEBBIE
View attachment 94094View attachment 94095View attachment 94096
didnt even know about it.. where\when is itIf no rain are you planning on attending 3rd gen expo tomorrow?
