Some interpretation needed.
In an effort to determine which side of the #6 cylinder is causing the engine tapping or ticking with loss of compression, I did the following procedure: removed spark plug and replaced with adapter ( hose with spark plug threads to NPT). Pulled fuel pump control fuses (2) and cranked engine until #6 was more or less at TDC on compression stroke by covering the open end of the adapter with my finger. No doubt when compression was reached. Then I introduced low volume (60lbs) of air through adapter into the cylinder and listened for air leaks at exhaust (drivers side) and throttle body intake (blades opened). The wife helped.
The results were: no air or sound of air escaping from tail pipe. I could hear air from the throttle body but not feel anything on my hand. Cylinder did hold pressure but it was only for a few moments before I released it.
Is this normal? or is intake leaking and being vented through manifold vacuum lines or past other orifices? Is this procedure logical?
This is to give a shop some info when I eventually take the car to them in February.
Cruzer from MM.net has confidence in the Dallas area SVT dealership. He interviewed them for me and feels that know what they are doing, have done this repair many times and may even give me a fleet rate discount.
However they are 190 miles away, would it be harmful to the motor to drive over?
Thanks,
Pat
pull the timing cover and removed the head and know 100% where the problem is.
You've gone this far, you can do it!!! :clap:
Its really not all that hard to do and you can pull it with the headers (if you have them) intact
If you end up needing a block check out JDM http://www.modularfords.com/forums/f155/jdm-302ef-stroker-shortblock-special-178747/
