Diff rear pinion seal leaking?
nytebyte
Not Politically Correct
Mar 2, 2004
13,705
21,234
I brought the Cobra in to have the differential cover seal fixed (still under warranty). The dealer just called and said that it's NOT the diff cover seal, but the rear pinion seal on the diff.
When I inspected the diff, it sure looked to me like the cover seal was leaking, but it might have just been oil blowing back from a leaking pinion seal.
Does this sound kosher?
jaykruger
Juiced, ported and blown
Mar 30, 2007
2,444
It is possible how many miles are on it? If it is low the shims for the gears might be off and caused the premature failure of the seal. Regardless the should replace it and the diff cover seal. Are they trying to charge you for it as a non warranty item?
ShelbyGuy
Turgid Member
Mar 26, 2004
5,230
road course usage causes flex on the snout. the hardcore guys have had trouble with the housing adding extra 'crush' to the crush sleeve so they switch to the solid pinion spacer to keep the preload within spec on the outer pinion bearing.
to replace the pinion seal, the differential carrier has to come out so you can get the pinion gear out.
spec for the preload on used pinion gears is 8-14 in/lb.
TCG Member 5219
12,447
18
Yes it does. My old cobra had the same thing happen. They replaced mine under warranty. I too thought it was the rear diff, but the air blowing it back sent the fluid to the cover. No worries, just check it after they fix it every couple of weeks.
