Chevy guys CEL questions
Lord Tin Foilhat
60,728
56,892
Privy Chamber
alright so i just need someone to double check and see if im right here. im throwing 2 codes after replacing my headers / dp with hi-flow
P1133 Heated Oxygen Sensor (HO2S) insufficient switching bank 1 sensor 1(Rear Bank)
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
now im pretty sure p0420 is because the new cat is flowing more then the stock cat, which would throw that code.
for P1133 if im reading it right (and according to my wideband) the computer isnt sweeping like it should be to get stoich (14.6) AFR. and bank 1 sensor 1 is the first O2 right? so my guess would be in open loop mode the O2 cant sweep (bad sensor?) and either goes to lean or to rich during idle (which shows on my wideband because its either in the 13's stuck at 14.1-14.4, or goes up to 15, 16 which is lean)
can anyone of the techs correct me if im wrong?
Nasty93
Nasty93
Oct 17, 2007
1,162
The Unit
no... i mean the intake manifold gasket. i believe there was even a recall/tsb on it. that would definetly throw off your AF, as many 5.3/ 6.0 truck owners can attest to
that wont fix that.
thats for a p0171 and p0174 bank 1/2 lean codes.
the first code you posted is talking about you heater circut for your 02, bank 1 sensor 1. So thats PRE cat, sounds like a bad 02. almost all heater codes are because of a bad 02.
the 2nd one is basically saying your new cat sucks dick for money. Its not as efficient as your stock one and sensor 2 the catalyst monitoring sensor is picking that up. Its obviously seeing excessive hydrocarbons based on the fact that you dont have a stock cat. This will cause the PCM to change your AF based on that
Eagle
Nemo me impune lacessit
63,909
4,744
Woodsticks, IL
After freeing up the exhaust flow a bit, I'd expect it to be a bit lean. 15's isn't unheard of @ idle. Have you reworked your VE table(s) yet?
I wouldn't expect your rear O2 to just mysteriously die after upgrades like this. Also, that post-cat-O2 is pretty sensitive. You could go the route I did and just disable those codes... :p
Eagle
63,909
4,744
Woodsticks, IL
Good link on P1133:
http://service.gm.com/gmspo/mode6/pdf/2005/2005file5b.pdf
Also looks like there could be a TSB on your fuel pump (the ION is the same car basically):
Make : SATURN
Model : ION
Year : 2007
Manufacturer : GENERAL MOTORS CORP.
Service Bulletin Num : 060604047
Date of Bulletin: OCT 01, 2006
NHTSA Item Number: 10020888
Component: FUEL SYSTEM, GASOLINE:DELIVERY:FUEL PUMP
Summary:
SES LIGHT ILLUMINATED, DTC'S P0171, P0300, P1133 SET, REDUCED PERFORMANCE, HARD START, INTERMITTENT LACK OF POWER. *KB
*edit* found the TSBs for the Cobalt:
Make : CHEVROLET
Model : COBALT
Year : 2007
Summary:
Make : CHEVROLET
Model : COBALT
Year : 2007
Service Bulletin Num : 3875
Date of Bulletin: JAN 01, 1901
NHTSA Item Number: 10020971
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary:
INTERMITTENT POWER LOSS IN HIGH AMBIENT TEMPERATURES WITH POSSIBLE DTC'S P0171, P0300, AND/OR P1133. *KB
Nasty93
Nasty93
Oct 17, 2007
1,162
The Unit
oh i know lol. that was my guess aswell. :bigthumb:
i just cant get a new fuel pump for free from that tsb :rofl:
TSBs Arent recalls. Dosent mean you automatically get free parts :)
All its for is to guide a technician's diagnosis of a vehicle. No way is it an extension of factory warranty (unless the tsb is based on a campaign in which it will explain that) I haven't been involved with this TSB at all. When i get to work ill poke around SI and see what i find about that
Bru
10,220
I've been dealing with the P1133 and P0133 codes with a new Denso O2 that was installed at the time the headers went on. As soon as I would clear the code it would pop on after driving for 5 minutes. Also, there was a code for heater circuit, too.
When the original ACDelco O2 was put back in, those codes didn't pop up anymore. I'm running the stocker right now with no codes.
118,952
yea, unless you're "in" with the dealer, which i think you car....id imagine ull have a hard time getting them to replace the rear o2 sensor at least since u removed the stock cat...who knows tho, they probably wont notice/care
